transmission distance in radio communication
bhuvanesh
Aug 29, 2013
201
i have bought all the components to make radio transmitter and receiver.but i am week at basics i dont know which factor cause effect on transmission.i mean which decides transmission range
14,311
There are many factors:
  • transmitted power
  • gain of transmittting antenna (including e.g. directionality)
  • losses during transmission (attenuation by obstacles like walls, humidity etc.)
  • gain of receiving antenna
  • sensitivity of receiver
  • robustness of the transmission's coding scheme (AM, FM, QAM, ...)
  • robustness of any higher layer coding (e.g. use of errror correcting codes etc.)
  • accepted signal-to-noise ratio of the received and decoded signal
14,485
losses in feed lines
and last but not least
the frequency used ( which probably should be at the top of the list)
shrtrnd
Jan 15, 2010
3,902
I'm kind of assuming this is an inside your home device?
A liitle more specific information would help.
Are you working a signal device like an on-off switch, or a communications device, like your own short-range FM radio station?
