Transmitter circuit operation explanation
Yap
Feb 13, 2017
14
Hi everyone. I am a newbie in communication field. Can anyone explain to me how the oscillator part works and the function of the preset capacitor in that part ? Thank you very much
duke37
Jan 9, 2011
5,364
There is a parallel circuit with a several capacitors across the coil. The preset capacitor is to set the frequency to that required. It is FM modulated by the two variable capacitance diodes driven by the audio amplifier.
The fet is a source follower to drive the circuit and the gate is driven from a higher impedance tap to the circuit.
The oscillator is followed by two amplifiers with feedback resistors to set input and output impedance.
CDRIVE
May 8, 2012
4,960
Actually Trevor, it's a classic Colpitts for sure but since the output signal is picked off the Drain I think I'd have to classify it as a Common Source.
Chris
duke37
Jan 9, 2011
5,364
There are many types of oscillator, given different names. This one would be a classic Colpitts without C3. It has a whiff of Clapp about it.
The best exposition of oscillators that I have seen is "Electronic Designers' Handbook" by Landee, Davis and Albrecht.
14,486
the trimmer, C3 is only for osc freq adjustment
duke37
Jan 9, 2011
5,364
Sorry, my mistake, should have said C4. Will have to get my eyes amplified.:rolleyes:
Yap
Feb 13, 2017
14
HMMM.i still cant understand the function of C4 and R5
Yap
Feb 13, 2017
14
and can anyone explain to me why there are two capacitors connected in before the dual gate mosfet?
CDRIVE
May 8, 2012
4,960
All components within the red border form the resonant tank circuit. R6 affects the "Q" of the tank as well as providing a DC path (that the gate needs) to GND. Neglecting the Gate to Source and Gate to Drain capacitance all remaining components affect the frequency of the oscillator.
C5, C6 and L2 form the positive feedback loop that all oscillators need to ...uh ... oscillate. :)
Chris
duke37
Jan 9, 2011
5,364
R5 reverse biases the two variable capacitors so they do not pass current. The audio amplifier swings this bias up and down so varying the capacitance and thus the frequency. These are diodes optimised for capacity change but in my day we used standard rectifying diodes such as the BY100.
Draw out the tank circuit and see that it has one inductor with several capacitors across it
CD1&CD2, C3, C4&C5&C6.
The fet drives the circuit across C6 and takes its input across C5.
C4 is perhaps there to isolate the DC short that the inductor would give. With a juction transistor this would generate a negative bias on the base but this is not the case here with an insulated gate.
The capacitors are sized to give the right frequency and the right impedance to connect the fet.
CDRIVE
May 8, 2012
4,960
Well Trevor, you're not as bold as I am (birthday in profile) but your secret is now out. :p
Chris
CDRIVE
May 8, 2012
4,960
Ha, if I read that correctly, soon we'll be able to carbon date you like a fossil! :D
"Trevorsaur" (humanusbipodus) I like it! It rolls right off the tongue.
Chris
Yap
Feb 13, 2017
14
Oh my god thank you very much. I totally understood how it works. By the way, may i know which website can i buy a 27farad capacitor?
Yap
Feb 13, 2017
14
and the C4 will block the DC, how come the MOSFET be biased?
duke37
Jan 9, 2011
5,364
R6 100k holds the gate at around zero volts. Normally this would have a diode across it so that the gate would be biased negatively when the oscillator is working, giving a level control and reducing distortion.
CDRIVE
May 8, 2012
4,960
Because it's not a MOSFET. It's a dual gate JFET. Unlike N Chanel MOSFETS JFETS conduct between the Source & Drain with no bias on the Gate. Their characteristics more closely resemble that of a Vacuum Tube than a MOSFET. R8 (as small as it might be) provides some negative bias between the Gate and Source.
Chris.
duke37
Jan 9, 2011
5,364
Chris.
I looked up the BF982 and I found it is a MOSFET. It has protection diodes across the gates which will act as oscillation limiters and provide AGC action so no additional diode is necessary.
Arouse1973
Adam
Dec 18, 2013
5,178
It also smells a bit like a tri-tet :)
CDRIVE
May 8, 2012
4,960
Damn! As I typed that there was a little voice saying "Are you sure of this? Check this FET out before committing yourself ".
I should have listened to the little voice. Either that or the little voice should have been louder! :) Looking again at the schematic symbol I shouldn't have made such a nube mistake. :oops:
Chris
