If you have a look on drawings I have drawn in red, I found something really weird. Resistor R28. When I measure it it shows 1.7Mohm one way and whe I swap leads it shows 150kOhm dropping slowly to 42kOhm then jums up tu 70 and drops again.
Readings below a resistor's value are nothing to be surprised about. It sounds like there's a capacitor nearby and you're seeing that charge up. Perhaps there is some active part of the circuit which turns on as the voltage rises to some point.
The resistance of 1.7M is only significant if the resistor is less than 1.7M. If the resistor is less than 1.7M, replace it.
Also D2 and D7. They are N4004. On diode mode they show nothing even if I swap leads. I bought diodes and replace them but having same readings. I got 20 of them and even brsnd new have same problem. I was using amprobe multimeter and I thought it might be faulty so I tested same componentswith fluke 123 and having same results. It is really weird.
sounds like you're doing something wrong.
Try reading the (new) diodes both ways on the resistance range. Do you have the meter leads in the correct sockets?
[/quote]I tested also other components. I draw cap U4 on my drawings but that is actually voltage regulator 7815ct. It has 22vac input and 15vdc output so seems to be ok. From there I decided to test mc33153p ones again. Results are as follows
Pin 1 and 6 15vdc
Pin 1 and 5 0.3vdc
Pin 1 and 4 8.05vdc
Pins 1, 2, 3 and 8 are joined together
Will keep testing but I am running out of ideas.[/quote]
All we're interested in at the moment are the signals running between the 2 boards. Do any of them change when you push the button (or whatever) to start the motor, or when the error shows up on the display?
Also talking about signal switching the motor on and off. I mensioned that if I switch motor on the LED switches on but I cannot find any connectin regarding this. I also checked voltage of tlp561g on pins 1 and 2 and getting 1.3vdc on motor on or off. I was wandering about pc817 but have no idea how to test it
And next weird thing. I said before that there is no voltage on motor pinouts on mcb when I switch motor on. Whe I disconnect the motor and switch it on, I am getting 300vdc on motor pinouts. I decided to check it again and put the probes to M- and R28 where R28 joints with C16 and Q4. I had 325vdc readings. That was measured with motor connected to mcb and pressed start button
I'm not particularly interested in this at the moment. It looks like power is switched to the motor circuit independent of the motor IGBT being turned on. It seems like you're seeing leakage across the IGBT. This matches the "I see voltage without the motor but not with the motor" symptom.
