trends in op-amp packages
Adam S
I'm wondering what will happen to the size of the common op-amp in the
next 5 years or so. Now, many new op-amps are no longer available in
DIP, and some recent devices are not even available in SOP (1.27mm pin
pitch), although at present this seems to be the most universal op-amp
package. The use of TSSOP/MSOP (0.65mm pitch) are on the increase and
singles in a SOT23-5 (0.95mm pitch) or SC70-5 (0.65mm pitch) appeared to
be more preferred.
Is is wise for new designs to avoid SOP packages ?
Jim Thompson
be more preferred.
I often have 40-50 OpAmps in ONE of my packages ;-)
...Jim Thompson
Joerg
Hello Jim,
Could have really used that in the design I am wrapping up right now. 13
functions in five chips, plus lots of discretes and it all has to go
onto half a square inch double-sided. I sure hope the assemblers don't
misplace any parts because it'll be a bear to find out with all those
0201 packages in there.
As to Adam's question, I'd just make sure to pick true "jelly-bean"
parts. LPV324 or whatever. Avoid high-priced boutique parts that might
go obsolete. Heck, my old work horse LM324 is still available in DIP and
that thing almost dates back to the days of Methusaleh. But it does
slowly migrate towards smaller packages. For a new design I believe
TSSOP is a good bet. By the time that package might be discontinued
we'll all be retired.
Sales guys are often quick to announce the demise of a certain
technology. We have to take that with a grain of salt. In the 90's they
told me the CD4000 series would be history in a couple years. Duh. None
of this happened. Also, lots of "modern" electronics use through-hole.
Open a newer TV set and you'll see a huge phenolic (!) circuit board
which is often single-sided. These are full of classic through-hole parts.
Regards, Joerg
martin griffith
...Jim Thompson
So how many of them do you get to work? :)
martin
Al Clark
All of them ;-)
...Jim Thompson
I have been increasingly moving to MSOPs for Op Amps. The biggest issue
is that they are generally only available on T/R. There are are a few
companies that provide smaller reels of 250 and some distributors sell
Cut Tape.
I usually avoid SSOP over TSSOP for logic. The TSSOPs are smaller and are
usually available in both tubes and T/R.
I don't see any compelling reason to use the larger part when both are
readily available. The .65mm pitch is not harder to solder than an SO.
I can't remember the last time I used a DIP op amp. I use thru hole for
connectors and crystals and almost nothing else. Thru hole connectors are
easier to align and are more robust. I use HC-49 thru hole crystals since
the crystal manufacturers have never adopted a "universal" SMT package
that I can buy for 25 cents. I can usually get just about any standard
frequency in HC-49.
