Trickle Charge Batteries
spike1947
Feb 4, 2016
68
Hi
I am wanting to know how I can rig up a simple trickle charge for 4 x AAA Ni-MH Rechargeable Batteries .I need them to run a 5 volt laser for a security set up I am making .
cheers
spike
cjdelphi
Oct 26, 2011
1,166
How simple? 4 x 1.2v = 4.8v
Get an adjustable regulator, set 4.8v and stick a resistor on it to trickle charge..
I've never been too sure about charging cells in series, but i think nimh cells don't mind too much
Arouse1973
Adam
Dec 18, 2013
5,178
LM317 as a current source, used this for years charging 7.2 volt NIMH, with no probs.
Adam
spike1947
Feb 4, 2016
68
Hi cjdelphi
I don't want to buy a regulator I want to build my own ! .
cheers
spike
You can charge them forever at C/20. Any higher and it gets complicated.
cjdelphi
Oct 26, 2011
1,166
A couple of transistors and a sense resistor for current regulation? Cheaper and quicker if you buy an lm317/resistor
Substitute the 10ohm resistor for a value that trickle charges your battery... i selected 10ohm as it sounded reasonable to charge your batteries, just provide the circuit a higher voltage than your battery total voltage
All that is needed is a voltage source significantly higher than the batteries full charge voltage and a resistor. The resistor should be calculated to drop (Vin - Vbatt) at a current of C / 20.
This will cause a higher charging current when the battery is depleted, which is okay, going down to the C/20 current when the battery is fully charged.
spike1947
Feb 4, 2016
68
Thanks guys , very helpful I now have all the info I need to crack on .
cheers
spike
Alec_t
Jul 7, 2015
3,820
As explained on the other forum, you need a supply to handle the laser current plus a trickle charge.
