I would like to know if i can make a ic in tssop (or other package) to fit in a breadboard,that only accepts dip packages.Is there any kind of adaptor in the stores that i can purchase or should i try and make my own?
Thank you MP,i found what i was looking for but they are very expensive.Isn't there any way to use a TSSOP package in my breadboard test circuit besides using a converter?
You must have pins to plug into the breadboard. Another route is to make an adapter yourself. Just use a board layout program like Eagle and terminate all of the pins to in-line pins which will allow you to plug into your breadboard. This is how I made a PLCC to 40 pin DIP adapter for my programmer.
One guy here where I work does some "moonlighting" and has used, with some success, a small toaster oven to reflow solder paste on SMT PCB's. The only trick is to find the right temperature profile.
