Johnrobbinsjr
- Sep 4, 2017
- 12
- Joined
- Sep 4, 2017
- Messages
- 12
I need some help finding a board to replace the one that burnt out on my TV lift in my travel trailer. It operates off of 12v and drives a motor to raise and lower a tv using a screw gear. There is a momentary rocker switch that you press once to raise the tv and press the opposite side to lower the TV. The board recognizes the limit of travel by measuring the current. So you press up and the tv rises to the upper limit when the motor current increases at the top the motor stops. Some for going down. The label on the board says H-bridge motor control w/current monitor. I have looked at several H-boards, but can't find any that meet the same functionality. Any help would be great. I will contact the original manufacturer, but I doubt they will be helpful, and it is a holiday weekend.
