Delta Prime
- Jul 29, 2020
- 2,996
- Joined
- Jul 29, 2020
- Messages
- 2,996
We'll... "I'm" trying to find a solution to your first problem.I'm French
This is an older thread, but just making sure you have already tried the "soft reset procedure?" Here it is: Unplug from the wall. Leave it unplugged from the wall. Push and hold the power on button on the TV for 30-45 seconds. Let go of the power on button. Plug it back in, and see if it works.Hi, I'm new to this forum
I have the same TV and the same problem happens, when I turn on the TV, I don't hear anything, no click or anything, only the standby red light is on. Does anyone have an idea how to make my tv lg 55eg910v
voltage comes on the primary part of the power board, and there is nothing on the secondary part of the PB, everything is zero volts,
except that the red light has 3.5v standby,
as I think the main motherboard activates it via 100GEA IC maybe I'm wrong so I would like someone to help me how to solve this problem THANKS
Ovo je starija tema, ali samo provjerite jeste li već isprobali "proceduru mekog resetiranja?" Evo ga: Isključite iz zida. Ostavite ga isključenog sa zida. Pritisnite i držite dugme za uključivanje na TV-u 30-45 sekundi. Pustite dugme za uključivanje. Uključite ga ponovo i vidite da li radi.
Ok. Not a problem. Your next step would then be removing the board from the TV, take very clear photos of the front and back sides of the board, and post them here for us to look at.Thanks for the answer, I apologize because I didn't mention that I already have some experience in TV repair, but I already tried that a long time ago and it didn't work, so now I'm trying to find a solution, thank you, greetings
