The problem with DG fets is trying to maintain wideband response
and maintaining good noise match... (They usually like to see very
high impedance on the input.) This isn't always true, but the
HP PHEMTs will match much better.
I strongly suggest looking at devices with input impedance that is fairly
close to 50 (or 75) ohms. The greater the amount of needed conversion,
then the amount of circuit bandwidth and sensitivity to components gets
worse. Untuned transformers can help a little in that regard, but it is
best to avoid them also (esp on input, where the signal loss can be costly.)
When choosing a device where you want to use it in low noise application,
there is also an ideal source impedance where the NF will be best. Sometimes
this match requirement isn't critical, and sometimes it is fairly critical.
For low noise RF applications, you probably want to try to find components
whose input impedance is within 2:1 or 4:1 of the source impedance. You
can CERTAINLY use components outside of that range, but life is easier
if you are minimizing the matching issue. Also, the component noise match
is also important.
For DG fets, you'll find that the optimium source impedance for the best
noise match will be a fairly high impedance (at normal frequencies), and
the ideal impedance match will likely be even higher. When casually
looking at the S11 parameters for typical DG fets, you'll find that the
S11 will be something like 0.9998 or 1.0002 over at least part of the
range (ignoring the phase, and really that cannot be ignored in general.)
Most often, a device whose S11 is 0.9998 means that its input impedance
isn't generally very close to 50 ohms. An S11 figure of 1.0002 likely
means that the component is not very stable (which very roughly means
that more signal will be reflected to the input than supplied by the input
device.)
DG fets do have very good applications (relatively wide AGC, good
intermod characteristics, good noise behavior, etc.) For applications
where AGC isn't needed, then there are components that might likely
do much much better. The issue here is whether or not the user needs
'much much' better performance.
If you look at the ATF-54143 at 900MHz, you'll se that the S11 is
about 0.7 (ignoring phase), the S21 is about 14... This VERY ROUGHLY means
that only a very small amount of transformation is desirable at the input,
and the gain almost comes for free... This small amount of needed
transformation (implying a low loaded circuit Q) means that the parts
values shouldn't be very critical.
*When dealing with other kinds of components, it is likely
that the S21 would be much lower, and the S11/S22 are much
closer to '1.0', which implies a more challenging and likely
narrower bandwidth matching circuit. S11 values of nearly
1.0 can mean a very low impedance (e.g. BJTs) or very high
impedances (e.g. DG mosfet inputs.) When the S11/S22 values
show such a serious mismatch with 50ohms, the S21 (the gain)
will likely show much lower than one might expect. This is
because the gain of a 50ohm input/50ohm output circuit will
indeed be fairly low. When building circuits with the HP
PHEMTS, you'll notice that their gain and ease of use is
very high. Some of the PHEMTS have gm of approx 1mho, while
the good old J310 might have a gm of 0.01 or 0.02 mhos!!!
On the ATF54143 at 60ma and 900MHz, the optimum gamma for the input
is about 0.32 (well, with an angle of
60degrees), but shows that its noise match isn't too damned far
from 50ohms (or 75ohms.) Without any amtching, the NF is still
well under 0.5dB.
Bottom line, with relatively careful layout, the ATF54143 cannot
help but give gain and low noise. Most likely, with good layout,
and careful handling of LF gain and impedance (helping to minimize
intermod effects also), a very very simple circuit cannot help but
give 10-20dB of gain with almost 50mw of power output and <<1dB NF.
With an ATF54143, it is important to take advantage of the two
source leads, and keep them at about 1.6nh each (total of 0.8nh).
This means using good microstrip layout. To help flatten the
LF gain (and to help with intermod producing LF components), then
some parallel negative feedback (between drain and gate) will serious
help performance (at the cost of some NF, but there is some NF to
spare.)
John
