Two PCBs off of one power source
audioguru2
Apr 6, 2004
12,026
The value of the resistors for the MC34119 power amplifier don't matter much if they are all the same. Use 10k and it will be fine.
The same for the capacitors.
The 0.1uF can be 0.1uF to 10uF.
The 1uF can be 0.1uF to 10uF.
The 5uF can be 0.1uF to 22uf.
The 100uF can be 10uF to 1000uF.
CALAHAN
Sep 13, 2006
71
Audioguru,
The 3.3k ohms can be replaced with 10k ohms?
Bruce
audioguru2
Apr 6, 2004
12,026
Yes, or 4.7k or 5.6k or 6.8k or many other values above 3.3k and below about 100k and they are the same.
CALAHAN
Sep 13, 2006
71
Audioguru,
Just an observation, but the line off the headphone lead you have me connected to alreay is being fed through a 3.3k and what appears to be a capacitor on the circuit board. I'll have to figure out which solder pont is which on that headphone jack where it is connected to the board. As I said, th ejack itself has been destroyed and used a mount for the Xmit switch.
Bruce
audioguru2
Apr 6, 2004
12,026
R107 is 3.3 ohms, not 3.3 thousand ohms. It and the capacitor connected to it keeps the power amplifier IC from oscillating. The 3.3 ohms resistor and the output for the headphones (and for your MC34119 power amplifier) is at the power amplifier IC pin 1. The jack had a built-in switch that disconnected the speaker when the headphones were plugged in.
CALAHAN
Sep 13, 2006
71
Audioguru,
Well I breadboarded it tonight. I wired it up to the values as you have it. I tried a few variables with the capacitors - both the 100 and 10 uf. I also used two 1.0 ufs instead of the 1.0 and 5.0 at pin 2 and 3 to ground. I found that the capacitors at these pins either diminished the volume or caused inconsistent sound. I removed them all together and left those two pins unconnected and it worked. It is at the brink of distortion but acceptable. These are regular alkalines by the way. I will be using AAA lithiums in the final version because I need to bring the amperage somewhat back up as I replaced the 3 AA for these 3 AAA's. I wonder what effect those will have.
I have a pristine FRS model of the one I hacked for the communicator, so I used this for the breadboard. I did exactly as you indicated. I took one of those "earbuds" and put into the headphone jack, cut the earpiece end of it off, stripped the wires, ran one to ground and the other to the breadboard as indicated and found that there is no sound coming through the speaker (I used a second FRS and created sound to be able to hear of course). I can hear the other FRS through the earpiece (I have two of those also), but the spliced one is not amplifying through the chip. Other then that, all is working.
Now what?
Bruce
audioguru2
Apr 6, 2004
12,026
AAA cells will produce exactly the same current to your circuit as AA cells except they are smaller and won't last as long.
Lithium keeps the voltage higher, longer than alkaline.
One wire from the earbuds is the signal and the other wire (pin 3 of its power amplifier) has a DC voltage that must not be connected to ground. Maybe your wires were mixed up. I showed the DC wire with a cut, then the earbud's wire was connected to ground.
If you connected pin 3 of the FRS power amplifier to ground then maybe the IC is blown up.
CALAHAN
Sep 13, 2006
71
Audioguru,
I can't solder wires to parts of the FRS circuit board. That would be very risky, even if I could find those locations you pointed out on it. As for the earbud, I plugged it into the headphone jack, the other end was stripped and I put alligator clips on the ends to the breadboard.  You mean to tell me that if I cross those two wires I stripped, the whole thing is blown?  I was under the assumption that one wire from the earbud was hot and the other ground. Is this not correct? there is nothing touching that one contact coming off the positive battery terminal in that jack array. I didn't do anything to the FRS circuit board. In fact, I took an unaltered earbud and snapped it in, and the sound does come through, so I doubt anything on the FRS is fried.
I will solder jump wires off the earbud stripped wires rather then use alligator clips and try that. The ear bud is very small, and the wires a mere few strands. I'll do this to ensure proper connection. It is either the connection or the breadboard.
Is there anyway of turning the volume down a bit with this chip?  As I had stated, I really didn't need the exra volume, and it is at near distortion at this point.
Bruce
Bruce
audioguru2
Apr 6, 2004
12,026
Hi Bruce,
Since an earbud still works then the power amplifier IC in the FRS radio is not blown.
One earphone wire has signal and the other earphone wire is not grounded and should not be grounded because it has a DC voltage. You need to connect the signal wire to the capacitor input of the MC34119 power amplifier and cut the DC wire from the earphones plug and not use it. The MC34119 can get its input ground connection through the battery negative terminal.
The value of one resistor determines the volume of the MC34119 power amplifier:
CALAHAN
Sep 13, 2006
71
Audioguru,
After looking at youir schematic again, I kind of figured you would say that. The MC34119 only needs the one wire out of the FRS, where I had both - one to the capacitor and the other to ground.
I'll reduce that resister also in my trials tonight. Can 1/4 watt resistors work? I need the smaller size to conserve space.
Bruce
audioguru2
Apr 6, 2004
12,026
The power dissipated in the resistors in your circuit is so low that I won't bother calculating it. Use 1/10W resistor for their small size if you want and they won't even get warm.
CALAHAN
Sep 13, 2006
71
Audioguru,
Well my friend, it worked.
I am very pleased. After I knew it would work, I started eliminating some of those pieces to see what could be done away with without changing the sound ( I need space). I was able to eliminate the two grounds completely off pins 2 and 3. And - I was able to eliminate the 100 uf capacitor to ground off of pin 5 altogether. No change in sound quality.
Here is one issue I am having. I reduced the resistor as you stated, which did in fact lower the volume to keep the sound effects from distortion, however, it also lowers the FRS peak volume too, and I need the FRS volume.
As I had stated earlier, the sound effects chip really actually uses 3 volts, but I have been running it on the 4.5 volts and it has not fried. It is even louder as I wanted. With the amp IC added, it is too loud now and distorts the speaker. I took a 69 ohm resistor and placed it between the power of the sound effects and the positive power rail. It reduced the volume to where I wanted it and cleaned up the distortion, however, there is a constant click present. I tried to add different values of resistor, and as I increased the value, the clicking stopped, but the volume also became low and unstable. Any ideas here?
Bruce
audioguru2
Apr 6, 2004
12,026
Good.
All battery-powered electronic circuits should have a supply bypass capacitor to keep a fairly stable supply voltage as the battery internal resistance increases as it runs down. The MC34119 amplifier might oscillate without a bypass capacitor when the battery gets a little used.
Of course. The negative feedback resistor controls the gain of the amplifier.
Increase the value of the input resistor to decrease the volume of that input.
A supply bypass capacitor across the IC would probably help but you don't have space for it. Try using two small diodes in series instead of the resistor. The diodes will reduce the voltage about 1.4V and will have a very low impedance.
CALAHAN
Sep 13, 2006
71
Audioguru,
I shoudl use those small black colored silicone diodes witht he white band from Radioshack? Out of curiosity, which was does the band face in the circuit?
And - for the heck of it, what does the supply bypass capacitor look like? Are you talking about returning the 10uf capacitor back?  The issues with that is the cylinder capacitor. If I could find a cermaic dick capacitor instead, I could find room for that.
Bruce
audioguru2
Apr 6, 2004
12,026
CALAHAN said:
I shoud use those small black colored silicone diodes with the white band from Radioshack? Out of curiosity, which was does the band face in the circuit?
Silicone is a flexible synthetic rubber. Transistors and diodes are made from very hard silicon.
Diodes have part numbers. RadioShack is not in Canada anymore and I can't remember which ones they sold. Use two 1N914 or 1N4148 small diodes in a glass case or use two 1N400x larger rectifier diodes in a black epoxy case.
The line on a diode is its cathode. Connect the positive terminal of the battery to the anode end of one diode and connect its cathode to the anode end of the second diode. Connect the cathode end of the second diode to the positive supply input of your sound effects circuit.
It is a capacitor across the supply in every battery-powered circuit. Your sound effects circuit has a 100uF supply bypass capacitor. Your FRS radio has a few of them. My MC34119 power amplifier circuit has a 100uF supply bypass capacitor but it will work if it is only 10uF.
What 10uF capacitor?
What is "returning back"?
I have never seen a ceramic dick. Hee, hee.
The biggest ceramic disc capacitor I have ever seen was 1uF but schematics on the internet have 22uF ones.
CALAHAN
Sep 13, 2006
71
Audioguru,
I don't know how to turn on the "reply with quote" function with this message board.
When I stated returning to the 10uf capacitor, I was refering to the fact that I have removed this from your schematic to save space and there was no noticable sound difference. Now that you state that is is needed for when the battieres start to die down, I will return it.  I'm sure someone out there sells a flat ceramic disk 10uf capacitor, but I wonder how big the thing is. The little 10uf culinder is not that bad, so I'll find the room.  I take it there is no issues with me removing the ground connections of of pins 2 and 3?  When I used them my sound was messed up with or without the capacitors.
Tonight I will just try and change the input resistor for the sound effects end to try and turn the volume down so it won't distort. If that does not work with the resistors I have on hand here, I will use the diodes. I do think I have a few of the glass Zener diodes here.
I also have a few 1N4001 Micro 1A Diodes
Here is the RadioShack page on them:
http://www.radioshack.com/product/index.jsp?productId=2036268&cp=&sr=1&origkw=diode&kw=diode&parentPage=search
I have the 1N4003 also which I think is the same as the 4001 but just can handle more input voltage.
I have two IN4733A Zeners also.
Bruce
audioguru2
Apr 6, 2004
12,026
Hi Bruce,
My MC34119 circuit uses a 100uF supply bypass capacitor but it will work with 10uF.
I have some very small 10uF electrolytic capacitors that I removed from old electronic things.
One wire of electrolytic capacitors is marked "-". It must not be connected with backwards polarity in a circuit.
The MC34119 should have a capacitor from pin 2 to ground and another capacitor from pin 3 to ground. It won't work if you grounded the pins. It might work without the capacitors.
The diodes I recommended are in the same small glass case as some zener diodes but they are not zener diodes. Use zener diodes if you want.
CALAHAN
Sep 13, 2006
71
Audioguru,
I'll look through some of the junk in garage for a capacitor that is smaller at 10uf, but will use the one I have if needed. There is not an issue with it working, it's just too big.
As for pins 2 and 3, I tried them with capacitors, and with direct connections to gound. Either way, the sound was heavily effected. When removing them altogether, the sound was fine with no connection to the pins at all.
Since I have the zeners here, I'll use them - if needed. The different resistor will be tried first.
Bruce
CALAHAN
Sep 13, 2006
71
Audioguru,
Something happened last night to the breadboard setup. It worked initially, but as soon as I connected the FRS, and tried to change resistor values out, the thing quit working. I put the multi-tester on the power input wire for the IC chip and it showed good, but putting the probe on the actual no. 6 IC contact showed no power. Something must have been grounding.  Also, I tried direct grounding pins 2 and 3, and all it gave me was reduced volume. Puttingin the 1.0 uf resisters caused the thing to squeel. I changed the whole assembly to different holes in the board, and it worked, however, it seems that I needed to use the two diodes to control the distortion of the sound effects circuit. I also experienced the clicking I was speaking about earlier which occures if the sound effects is hooked up to the breadboard and the FRS goes into power saving mode. The only way to get rid of it was to put in the two 1. capacitors, and this time the squeeling did not happen, and the whole circuit now works what appears to be perfectly.
Something went wrong on the breadboard and I do not know what.  Tonight I will attempt to solder the amplifier circuit together for actual use in the communicator. I will advise by the end of the weekend it this was a success. It looks as though there willbe no skimping on the different components after all.
If this works, I will build one of these for all of my future FRS communicator projects, unless of course I can find room for two seperate speakers. I will always need to power both on one power supply.
Are you any good with antennas?
Bruce
audioguru2
Apr 6, 2004
12,026
I never use a breadboard. The connections are always intermittent. I quickly sketch a parts layout then solder the parts and a few jumper wires (that do not cross) on stripboard.
Pin 2 and pin 3 of an MC34119 amplifier must never be grounded. They are supposed to have a filter capacitor to ground.
All i know about antennas is to use a quarter-wave whip or a half-wave dipole.
