Tom Del Rosso
- Jan 1, 1970
- 0
Still no industry standard? Which alloy do you like for repair of new
boards?
boards?
If you mean wire solder, we use pure tin. If you mean paste, it is SAC?Still no industry standard? Which alloy do you like for repair of new
boards?
Paul said:If you mean wire solder, we use pure tin. If you mean paste, it is
SAC? and I don't recall the number.
Arfa said:Of course, I
don't think that there is any such requirement to maintain the
original certification on your side of the pond. So I would say, go
right ahead, and use 'proper' solder to carry out your repairs, but
suck or wick as much of the lead-free solder off the joint as you
can, before remaking the joint.
Tom Del Rosso said:Will there not always be a residual film of the original solder, and would
that not cause a crack along the entire interface?
N_Cook said:It is the absence of lead rather than presence of tin that is causing
the problems, you have tin in both leaded and lead-free solder. It is
the lead that gives the forgiveness, perhaps someone knows the
technical rather than folksy term for this
