ultra low noise alternative
  • Thread starter .rhavin grobert
  • Start date
.rhavin grobert
could someone please recommend some alternatives for those chips:
TL 074CN
TL 072CP
i'd like to have some chips that have as few noise as possible. I dont
care if i have to spend some dollars for a chip, i want them to be pin-
compatible and nearly without noise. any suggestions?
TIA, .rhavin:)
Eeyore
TL 074CN
TL 072CP
Depends if the circuit needs the minute input current of bi-fet op-amps.
There's no shortage of really quiet bipolar ones at sensible prices.
Graham
neon
Oct 21, 2006
1,325
while a low noise amp is fine to begin with. it could all be for nothing if the shielding or traces are designed without that in mind.
GregS
Graham
I would think it depends on the circuit whether a bipolar would work. OPA4134 is a good bifet,
but you just can't expect it to work if you don't know the circuit. Power supply requirments
are essential. Then there's the LME49740.
greg
GregS
is a good bifet,
supply requirments
greg
I don't know why, but I was assuming audio applications. There are all kinds
of applications that need to be fit into the mix. Is this for instrumentation
and what is the circuit ?
greg
GregS
One big problem with the internet, unlike books, data disapears if
its not current.
greg
Eeyore
Indeed. The question needs to be more specific.
Lovely isn't it ? And it's dual friend the LME49720, not to mention a single too, the 49710. Singles
are rare these days but can come in handy.
Graham
Eeyore
That's what the TL07x series was designed for after all.
Graham
Eeyore
its not current.
Keep those good books ! ;~)
Graham
GregS
Graham
I have seen the TLO7x series in many applications.
For a long time I was bent on getting a TLO75 replacement. I guess
I got over it.
greg
Eeyore
Oh yes, they're very versatile and not especially expensive, so well adaptable to mnay circuits,
however that WAS their intended primary market.
I got over it.
BTW, it's TL zero seven (five), not Oh (the letter) seven (five). Just being pedantic ! ;~)
Graham
.rhavin grobert
greg
it for an trace elliot bass amp. see circuit here:
http://tinyurl.com/5cyfcp
except ic1, all ops are TL074. i already replaced ic1 with an OPA 2134
(excellent result) but still have some great humming even when nothing
is connected to the input and mute is pressed. it's definitivle the
main board, not the AHA.
so i wanted to replace all those cheap noisy TL074 with the OPA 4134 -
unfortunately, the PA series (DIP14) is dead;-)
Eeyore
Changing op-amps won't affect humming one tiny bit. You have some other problem. Could be all sorts
of things. Take it to a tech.
Graham
.rhavin grobert
Graham
i am the tech! ;-) the humming is my 2nd problem, i first have to
solve the noise, and as the TL074 are pretty good noise generators, i
want to change them first to have a "clean hum" to start look for and
as the OPA 4134 is dead, i was looking for some other alternative.
Eeyore
Must be a pretty cruddy circuit if TL074s are noisy in a guitar amp !
I guess you're going to be looking at a TI/BB or AD device but I'm not up to date on low noise fet input
devices, I tend to use bipolar myself.
I'll tell you one thing though. Modern TL0's may be a fraction quieter than old ones. I know the
TL081/2/4 spec changed.
You might want to post in sci.electronics.design. Lots of people are well up on their devices there.
Graham
GregS
You were given two models.
Put some sockets in there and compare.
greg
GregS
to mnay circuits,
pedantic ! ;~)
Graham
I have been saying TL O for 30 years. Now I stand corrected.
greg
Eeyore
I SAY it that way too but write it the other way. In the UK (and I'm sure the USA too) 'oh' is often
used colloquially to mean zero but not written like that.
Graham
