Ultrasonic Range Meter
Ban
Martin said:
Hi Jon,
I think 50m is way too far too actually. There's this paper on
ultrasonic ceramic transducers on
www.senscomp.com/specs/piezo%20application%20note.pdf and it explains
all the losses and such.
For a 100V pp driver with a transducer's SPL of 108dB and the
receiver's sensitivity of -75db, according to my calculations, the
voltage at the receiver at 50m is about 0.2uV :)) With the help of a
cone I think this could get up a bit but still... Do you think I can
do anything with this?
Can I say my 2 cents:
atmospheric absorption at 40kHz is a whopping 150dB/100m (20C 70%H) at nasty
10kHz it would be only 18dB. So for larger distances go down with your
frequency.
Also your calculation seems off. 100m means -80dB (inverse square law). Then
there is absorption/diffusion at the reflector, let that be another 20dB.
This makes it -100dB. Your receiver needs 94-75= +19dB SPL, you have only
108 - 250 = -142dB available. Forget it.
You can concentrate your beam with an old satelite dish (not the offset
ones) by mounting the transceiver in there. This would maybe improve the
ratio by 30dB. But then any temperature gradients or air movement would
carry your beam away.
Figures are from "Sound System Engineering" by Davis&Davis, ISBN
0-240-80305-1
Martin
Thanks Ban. I want to point out that you were thinking 100m instead of
50m. :D I'm using that application note from senscomp (link in my
previous post) and the calculations seem right. SPL reduction at 50m is
20*log(30/5000) ~ -45dB.
There's one thing that was confusing though. According to senscomp's AN
and http://www.earthworksaudio.com/tech/hf_sound.pdf air absorption is
about 15dB for 50m. However, according to numerous atmospheric
absorption (based on ISO 9613-1) calculators, this value should be
about 1.2 - 1.3dB/m (about the same with your value 150dB/100m) for a
40kHz signal at 20 degrees C and 70%.
I suppose ISO 9613 must be right. So 50m seems a bride too far here.
Martin
I suppose ISO 9613 must be right. So 50m seems a bridge too far here.
Ban
is 20*log(30/5000) ~ -45dB.
AN and http://www.earthworksaudio.com/tech/hf_sound.pdf air
absorption is about 15dB for 50m. However, according to numerous
atmospheric absorption (based on ISO 9613-1) calculators, this value
should be about 1.2 - 1.3dB/m (about the same with your value
150dB/100m) for a 40kHz signal at 20 degrees C and 70%.
That guy is an idiot, for 1kHz it is 0.7dB/100m, it is also not the frequncy
sqared, but has two plateaus, where the nitrogen(0.6dB/100m) and
oxygen(300dB/100m) levels are, which are then constant for all higher freq
in this gas alone.
Rich Grise
Hey Chris,
I'm doing a project on ultrasonic ranging too and the desired distance
is 50m. It seems rather far and I wonder if TC4420/4429 could help? And
can you explain how these things work cos I'm really confused about how
6A would help driving my transducer. :-/
Martin
I wouldn't even bother to try ultrasonics beyond about maybe 3M (10 feet),
for a whole bunch of reasons. But, laser rangefinders for maybe 10' and
farther are available off-the-shelf:
http://www.google.com/search?q=laser+rangefinder
So I'd look at the minimum range on the lasers, and do the ultrasonics
for short-range sensors. ;-) (also pretty much off-the-shelf.)
Who's Chris?
Good Luck!
Rich
Jonathan Kirwan
<snip>
Just as a note: Radio Shack has an off-the-shelf ultrasonic unit that
claims 3cm to 300cm (3m) range. Cost is under US$15 until some time
in June (it's on sale -- half price.) It's a unit for the Vex robot
kit thing.
Jon
