Not necessarily, since that depends on the amplitude and frequency
of the ripple and how long it takes +V to get through the 75V
threshold, neither of which the OP specified.
Also, note that the ripple on +V will be attenuated about 37.5dB by
the divider on the non-inverting input of the comparator.
As will the voltage being measured. If the low frequency ripple on the
HV rail were only 5%, loaded, you'd want a window around the detection
points to overcome this.
If inrush limiters are thermally dependant, you'd also have to account
for supply droop as these heated up to their low resistance state, in
order to avoid loaded motorboating at low line. A simple slow start
circuit is seldom able to account for relatively long thermal time
constants.
HF ripple and pin signal noise is another issue, but the principal is
the same in most power electronic circuits.
RL
