Uniden Um 425 marine radio
vstyn
Aug 30, 2016
5
I turn the radio on, and Its great for 5 to 10 minutes. Then, I lose all sound, the radio still has power (lcd display is lite), but no sound.
I then turn the radio off for few minutes. Then, I turn back on, and the radio works with sound, and 5 to 10 minutes later, I get no sound, but the radio lcd display is lite.
thanks
vic
kellys_eye
Jun 25, 2010
6,512
Is the supply ok? Not using a dud battery are you?
Possible overheating issue with the audio circuitry - has the set been opened recently?
vstyn
Aug 30, 2016
5
no battery is good with good voltage. I agree about over heating, but where to check?
14,487
audio amplifier stages
also check that if using an external speak, there isn't a short circuit in the plug, wire to speaker
if there is, it may be putting undue load on the amplifier and causing it to overheat an fail
otherwise it's likely to just be an amplifier cct problem
show us a sharp and well lit photo of both sides of the circuit board and we can see if the audio cct can be identified
