Unknown Transformer secondary Amperage
lferreira
Apr 19, 2010
3
I've got an transformer of 220v - 12v. The problem is that i don't know the amperage gived by the secondary. How can i know it?
Is it possible to know it if i put an amperimeter in short circuit? i'm afraid to burn it if i do.
btw, sorry for the ignorance. :)
If there's a part number on it, then maybe someone can look it up.
If it came from a device that you have the circuit for, then we may be able to make a guess.
Yes, shorting it will damage it.
Resqueline
Jul 31, 2009
2,848
The size & weight of it will be tightly correlated to the VA rating of it (just compare it with similar xformers), and the gage of the wires tells you the Amp rating.
Shorting it for 1 second won't damage it afaik but it won't give you much useful information.
lferreira
Apr 19, 2010
3
The transformer was originally from an Mustek UPS.
the part number on it is the following:
080-48183-01
GP 0721
Class B Viking B-2
E210832
the size is of it is 8cm (3.14 inches)
primary 220v
secondary 12v
There are 2 mentions of this transformer that I can find on the internet. Both seem to be talking about the same thing.
The consensus is that the part numbers may refer to the core and that it may be a "custom" transformer.
I can't confirm this information (obviously).
It may be a very good idea to determine the gauge of the wire. It may indicate a ballpark figure for the current.
lferreira
Apr 19, 2010
3
well, i've been digging a little bit, and the transformer originally was on a 600VA UPS
at least 250W of electricity the primary is giving when working as an inverter from 12v-220v. ( i know that it should be more)
assuming that the efficiency of the transformer must be at least 0.6 (worst case scenario)
making the math, that A=P/V
then
A = (250/12) * Efficiency(0.6)
so i get 12,5 Amp out of it (at least)
am i assuming wrong?
the only thing that it will be is for a battery charger, so i assume that it will be enought to start working on the circuit charger?
jteachout
Oct 1, 2010
I'm a novelist at best I have the same transformer I would like to know how to connect the wires I'm also looking for step-down high amp use
mvarga
May 30, 2011
My transformer marke are :
080 - 48155-02
GP 0712
Class B Viking B-2
E210832
has anybody the scheme for the wires?
