Unsiged Char
juantravel
May 14, 2010
41
Hello forum :)
I have decided to start programming my pics with C. Ive gotton most of it down except for unsigned char. Signed char(char) gives you a range of -128 to 127 and unsigned char which is 0 to 255. What is the difference?
LTX71CM
May 23, 2010
182
Both char and unsigned char represent the same number of values but unsigned char is purely positive. If you're doing math and the result is 150 and you assign that to a signed char your micro will think it represents -22, clearly a problem. If you need to represent a bigger number you'd use an int or unsigned int (-32.768-32.767 vs 65535).
juantravel
May 14, 2010
41
unsigned char
Its just a little more confusing when i saw
Code:
#include <htc.h>
void eetest(void) {
unsigned char value = 1;
unsigned char address = 0;
// write value to EEPROM address
eeprom_write(address, value);
// read from EEPROM at address
value = eeprom_read(address);
Why would they assign the memory address as a unsigned char?
juantravel
May 14, 2010
41
unsigned char
Thats where the confusion comes in... what if we need to save something in eeprom address 23. char only holds 1 character now we have 2 or does it go buy value 0-255...which in that case can only read 255 address spaces? If that is correct.. after 255 address space then we use unsigned int?
unsigned char is 1 byte size. If we are only using 0-255 values there is no need to call for int which takes 2 bytes right?
You MUST use:
1) a datatype legal for the function
2) a datatype which can hold the value you require
LTX71CM
May 23, 2010
182
Correct, you're on the right track.
juantravel
May 14, 2010
41
Thank you
You have both been very helpful...I also hope someone will find these threads helpful. Is there a way to give thumbs up or rep?
