W
Watson A.Name - \Watt Sun, the Dark Remover\
- Jan 1, 1970
- 0
I I've had the 4 LEDs operating at 25 mA for all of May and June, and
the first few days of July. This is about 1500 hours so far. The LEDs
are two Nichia NSPW500BS white LEDs, and two white LEDs from Hong Kong
that I got off Ebay. All four are in series so there is no doubt that
they are all running at exactly the same current.
The two Nichias are going strong, with no noticeable signs of dimming.
The two Hong Kong LEDs, sad to say, are so dim that they wouldn't make
good panel lights, so can't even consider them suitable for
illumination. They're really quite dim.
Of the hundred Hong Kong LEDs I bought, all I've used have had this
dimming problem after a few hundredds of hours, so I decided to put the
four on a PS to control the conditions and verify that I'm not imagining
things. I think one problem might be that the Hong Kong LEDs use an
organic phosphor that degrades faster than Nichia's, and might
contaminate the LED chip. But I'm not an expert on this at all, so I'm
open to any other ideas.
I posted an update of the progress of the dimming at the beginning of
last month, and now this one shows that the hong kong LEDs are so dim
that it's probably not worth continuing the test. I may solder two more
unused hong kong LEDs into the circuit, and start the test again, just
for the halibut.
@@F@r@o@m@@O@r@a@n@g@e@@C@o@u@n@t@y@,@@C@a@l@,@@w@h@e@r@e@@
###Got a Question about ELECTRONICS? Check HERE First:###
http://users.pandora.be/educypedia/electronics/databank.htm
My email address is whitelisted. *All* email sent to it
goes directly to the trash unless you add NOSPAM in the
Subject: line with other stuff. alondra101 <at> hotmail.com
Don't be ripped off by the big book dealers. Go to the URL
that will give you a choice and save you money(up to half).
http://www.everybookstore.com You'll be glad you did!
Just when you thought you had all this figured out, the gov't
changed it: http://physics.nist.gov/cuu/Units/binary.html
@@t@h@e@@a@f@f@l@u@e@n@t@@m@e@e@t@@t@h@e@@E@f@f@l@u@e@n@t@@
for the halibut.
