Jamie
- Jan 1, 1970
- 0
i know that one, had little hot balls falling out of 690+ seriesPooh said:Ignoramus1797 wrote:
Be careful with them !
When the IGBTs fry - the driver normally goes too .
Graham
today! bye bye IGBT's
Graham
If I were to develop a unit with those chips, I would get an entire
*TUBE*. And I would probably use them, too. Until your gatedrive works
properly, it doesnt work properly. And gatedrives that dont work
properly cause explosions. Even when you are experienced and careful.
But there is a *LOT* to be learned from such an exercise.
solid groundplane underneath the circuit. And keep IGBT gatedrive
connection inductance low - 50nH is really too much, 10nH is better.
if you use a DIP proto-board, it will go *BANG* the first time you try
to use it on the welder.
Ignoramus24489 said:That's what I was, in fact, planning on doing. :-(
Is there some proto board type thing that is acceptable?
i
no, not really. the problem is the inevitable large physical loops that
exist. these pick up H fields, and convert them to troublesome voltages.
that in a gate drive always lead to a loud bang.
honestly, it would be far cheaper, at US$50 a pop, to buy a couple of
semikron drivers. the advantage here is that (provided you connect it
well to the IGBTs, minimising inductance) even if your logic goes
screwy, the gatedriver will prevent you from being able to blow the
IGBTs up.
or you could dead-bug your hardware, on top of a Cu-clad PCB as a ground
plane. I've built some pretty tricky stuff this way, and have seen
pictures on the web of some truly amazing gear - IIRC google "manhattan
style"
keep circuit loop inductances small. current flows in loops. even logic
signals.
Terry Given said:yep. Yuck!
:~p
always ensure base currents are limited. lest stuff fail during wierdo
start-up, shut-down or interference conditions.
in general, such linear
circuits have piss-poor performance. actual thresholds vary widely with
time, temperature and sock colour (or so it seems....). Use a real
reference voltage, and a proper comparator with suitable hysteresis.
likewise the desat detector is equally yuck. use an LM339
a pullup to (say) +15V.You lost me said:and just
measure Vc. there are 2 methods: a resistive divider, or an HV diode and >
Either way, note that Vce can be very, very
negative - even though the IGBT has a reverse diode, there is an
inductor between it and where you measure Vc.
Tim said:Good point, so that'd be um, 0.15 ohm emitter resistors or something in the
gate drive circuit then? (If not for: )
Ok. But why? I get good results (into MOSFETs, granted they don't handle
as much current) using an emitter follower and transformer for high and low
side gate drive. (Three state voltage output: +12V for high side, -12V for
low side, 0V inbetween states for both off.)
I can't do that here since I want a square wave that goes from +10 or +15V
to -5 or -10V, and I need some sort of active circuitry because just passing
that waveform through a transformer is going to poop on the DC offset,
especially as duty cycle is varied (from perhaps 25 to 48%; ultimately it
will be set to the upper limit, but for testing I want control). A
requirement of 15V on-state gate drive doesn't work when duty cycle is less
than 50% and your negative gate voltage limit is -20V!
Eh, that MIGHT work...![]()
So what of the high side Vsat? Do I need to float a 393 by the +rail?
Ah, true. Although, I don't really see just how high it can be if I'm
switching it over say 0.5 to 1uS. That's 50-100A/uS, but still... hm, but
Terry Given said:if its a complementary emitter-follower output stage, driving Cg thru
Rg, then you can happily use a base resistor Rb = Beta*Rg without really
buggering up your output. pick a seriously pessimistic beta though,
about 25% rated....
I'm referring to the ratshit desat circuit here. that threshold will be
truly awful.
then you have to do something trickier. the basic idea of the icky
gatedrive would work, but dont be afraid to hiff an LM339 or suchlike
in there.
<snip interesting modulator>If you are careful, you can also suck your supply rails out of
the same xfmr - eg voltage doubler for +ve and -ve rails, and a couple
of regulators (the -ve regulator can be pretty crude).
maybe. depends on how good a gate drive you want. I'd not bother, and
just sense desats on the lower igbts, its not very high power.
its probably not that hard to have a ground-referred high-side desat
detector, either. you would be looking for Vc of the lower transistor
failing to get within about 10V of Vdc when the upper transistor is on.
100A/us * 1uF = 100V negative spike. watch something break.
100A/us * 10nH = 1V negative spike. thats enough to make an LM339 output
go bonkers if its running from a unipolar supply.
And I'd like to see
you keep the inductance between the diode cathode and your Vc takeoff
point below 10nH for *any* package.
Tim said:That's true. Not always thinking clearly, as you've noticed. <g>
Yeah I'd go for say beta = 5 or 10.. typical saturation figure for power
transistors. Obviously that depends on what type I pick, which I haven't
picked yet...
Well okay, then swap the zener for something else...
I was told by a friend it would work, but he deals more with AF amps than HF
class D, too...
Well, what the heck do I need an extra fourteen pins for when I can use a
couple transistors to do the same thing? (Okay, so in the circuit I put
down four transistors which makes 12 pins which would probably cover a wider
footprint, but,,, that's beside the point!)
What, you mean use the gate drive for supply *and* switching? I don't think
the SG3524 would like that, although it does have 300mA output which would
go reasonably far at 12V (=4W). Haven't estimated gate power yet...
So what if there's a ground fault condition? I can hear a shotgun shell
going off yet the bottom transistor desat is aloof.
If I had some 400+ Vceo PNP's this could be a lot easier...
(Yeah, so buy some... I'm buying plenty of other things after all)
Hm.. I'm not seeing it work with a grounded op-amp that doesn't have 300V
common mode input range..
Um, abuse of units? Unless you typo'd uF instead of uH.
Yeah... >>So a small resistor and 1N4148 on the comp?
If you mean not so much keeping things working as getting erroneous output
bunnies, I was going to integrate it a little since the gate voltage is at
least 200nS ahead of the collector.
Izzat fine for IGBT + diode packages then? Well, not really... hmm in fact
it would be better to have an external diode since I could connect very near
the diode junction and keep it to a few nH.
Or I could put an integrator on to snub the 100nS-ian rectifier switching
hubub. Desat detector won't mind another half uS lag.........
