UPS and circuit breaker question
unknown
Nov 23, 2014
Hi all,
I just joined the electronics industry.
There are a lot of things I don't understand.
Firstly, why is UPS using voltage while a circuit breaker is using ampere.
Q1) There is no resistor between them so how does the "change" occur?
Q2) Are busbar and PE bar complete opposite of each other in terms of functions?
Q3) Does any of you know what this abbreviations stand for? IDU as well as PLTS??
Thanks in advance.
14,487
Hi all,
hi, welcome to the forums :)
circuit breakers / fuses are always rated in Amps ( at a certain max voltage) it can pass before it trips
I have no idea ... show us a circuit of the UPS you are referring to ??
A PE bar is a Protective Earth bar so depending on the installation and the local electrical regulations
There may be just a Phase and a Neutral bus bars The neutral may or may not be earthed
here in Australia and New Zealand, the Neutral is earthed at the switch/fuse box
other installations may require a Phase, Neutral and a separate PE bar
Q3) Does any of you know what this abbreviations stand for? IDU as well as PLTS ??
Thanks in advance.
IDU ---- has a zillion different uses
PLTS ---- has many meanings none related to your main subject ( electrical systems) that I could find
what context are you using them in ??
