UPS & Inverter
vivek_pv
Aug 2, 2006
43
Dears,
For house lighting purposes(assuming tubelights and Fans) which would be a good choice?
1. Sine-wave UPS
2. Square wave UPS
And what is the difference between UPS & inverter?
Regards,
V
audioguru2
Apr 6, 2004
12,026
Tube lights (fluorescent lights?) and fans usually don't need a sine-wave. A simple square-wave circuit is much easier to make than a sine-wave circuit.
An inverter generates fairly high voltage AC from a battery.
A UPS charges its battery, generates AC the same as an inverter and either runs all the time or switches itself on very quickly so its load isn't affected when the mains fails.
vivek_pv
Aug 2, 2006
43
thanks audioguru.
For fans and tubelights, do the inverter with 4047 suit?
Do we need a special transformer for square wave (by 4047)? or the would normal be sufficient?
Regards,
V
audioguru2
Apr 6, 2004
12,026
Our Low Cost 500W Inverter project was modified 2 years ago and works very well in The Philippines driving tube lights, fans and multi-voltage TVs. But it was recently changed and might blow up.
Normal? Have you ever seen a 230V/12V/50A transformer? Made for a welding machine or something that uses such a high current. If you can find one then it will be fine in a good square-wave inverter circuit.
Gazza1
Jul 25, 2006
66
vivek_pv said:
Dears,
1. Sine-wave UPS
2. Square wave UPS
Regards,
V
How much load do you want to run off of the UPS?
