Urgently Need Transistor Equivalent
thothset
Mar 1, 2017
14
please tell equivalent transistors for the following ...which can easily available and little bit cheap..
2П307B
2Т203А
2Т203Б
2Т203Г
2Т608Б
and because i'm nerd, please help me
1. how to find a equivalent. for example: what are the parameter to check between original transistor and equivalent? how can i judge that particular transistor is best equivalent.
2.Is application of transistor plays a role to find equivalent transistors? eg. switching and amplification etc..
please educate me.
14,482
1.polarity must be same eg. NPN will only match with NPN.
2.max voltage of Vcb,Vce,Veb
3.Max current of Ic
4.Max power Pd
5. Hfe
anything else?
yup
another words .... rated at least the same as the old transistor, doesn't matter is the ratings are a bit higher :)
anything else?
The most important thing is whatever is important in the circuit. There is rarely a single "best" equivalent unless the same transistor is manufactured by multiple sources (in which case they are likely to have very similar part numbers).
