USA wall wart in the UK
Bamse
Nov 9, 2018
10
I am getting a device from America that runs off a supplied wall wart. It's no doubt 12v or around that.
My question is, if I just get a USA 2pin to UK plug adapter, will this be sufficient? I wouldn't a step down converter?
14,487
look on the walwart and see if it has a voltage range input pretty much all of them do these days and most of them will work from 110 - 240VAC
Again, CHECK its label
Bamse
Nov 9, 2018
10
Great, thank you.
Audioguru
Sep 24, 2016
3,656
If the wall wart is lightweight and small then it does not have an old fashioned large and heavy low frequency transformer in it and instead it is a modern electronic circuit that uses a lightweight high frequency transformer. The modern ones work from a wide range of supply voltages.
Bamse
Nov 9, 2018
10
Yeah, I've got a pictures now and it's 110v - 240v so should be fine. Thanks
