USB: FTDI chip or HID?
Marco Trapanese
I need to design a board which should send data to a computer via USB.
The data is composed of a packet of about 25/30 bytes sent every 10 ms.
A software running on the PC side should receive this information and
store it on a file.
I'm wondering if it's better to use an FTDI chip and make the things
easy using a virtual COM port or to implement a "true" USB communication
(HID?).
I'm afraid about the speed needed to receive and save the string into a
file.
What do you recommend?
Marco
Martin Riddle
Marco Trapanese said:
ms. A software running on the PC side should receive this information
and store it on a file.
communication (HID?).
a file.
Marco
FTDI chip, Then you don't need a PID and VID since its in the FTDI
already.
<http://www.ftdichip.com/Support/Doc...tomising_FTDI_VID_PID_In_Linux(FT_000081).pdf>
Cheers
Marco Trapanese
Il 17/10/2010 23:57, David Brown ha scritto:
What makes you think that a virtual COM port with an FTDI chip is not
"true" USB communication?
The "other end". On the pc side if I use a virtual COM port I need to
receive data from it.
I was thinking that a custom driver that get data directly from a USB
class could be faster.
HID is a USB class, and makes sense if you are making a mouse or a
keyboard, or something that will act like a mouse or keyboard. It
certainly does not sound like that's what you are doing.
You're right. I used HID to make my own joystick controller, but I saw
people that use HID to exchange data.
A virtual COM port (using FTDI chips, or some other kind) is almost
certainly the easiest solution. You can pretend the FTDI chip is just an
RS-232 driver - you connect to it with a UART, and at the other end
you've got a new comms port on the computer. It works with any system
(plug and play on Linux, or by installing FTDI's drivers on Windows),
and you can use a whole range of baud rates up to about 3 MBaud.
Ok, I got it.
I thank all other guys who answered me.
Marco
Jamie
Ok, I got it.
Marco
http://www.saelig.com/pr/quickusbmodule.html
Have a look at that..
