USBC
Rajinder
Jan 30, 2016
568
Hi all,
I am using a USB C connector in a design. This is a receptacle that fits into a PCB.
There are 2 x D- and D+ lines. These are connected together as per the guidelines. This is a through-hole connector.
I have attached a picture of the layout of the said connections. One set of tracking is on the Top layer and the other on the bottom layer of my PCB. There is no GND layer where the tracks are crossing.
I wanted to ask if I would need a GND plane for the part where the tracks cross over i.e. between the pins?
Or should I route both tracks on the Top and use X2 vias for one of the tracks and still add a GND plane only under these pins?
My PCB layer is Top (signals), GND, VCC and Bottom (power signals).
My other question is how to connect the shield of the USBC connector? Should it directly to 0V, or via a resistor to 0V. I see so many different ways. I have only used microUSB which I have connected the shield to 0V via a 0R resistor.
Any tips or advice?
