Using a PIR to turn a light OFF
AndyC
Oct 10, 2017
Hi!
I'm trying to find a "reverse PIR" (for want of a better description)! In other words, one where the light is permanently on, then when the PIR detects motion, it turns the light off, then after a fixed period the light automatically comes back on again. Anyone know where I can buy such a thing? I've googled it extensively, but - as you'd expect - all searches end up on pages talking about using PIRs in their normal switching-stuff-on role.
Failing that, anyone know how to make one? I'm an absolute electronics novice, but happy to try to follow a set of instructions! :)
Cheers,
Andy
Connect the pir to a relay and use the normally closed contacts to drive the load. When the pir activates, the relay is pulled in, turning the light off.
AndyC
Oct 10, 2017
Cheers guys! Shall ponder the relay option - that sounds like a possibility. Ta!
duke37
Jan 9, 2011
5,364
There may be a changeover relay in the PIR or you may be able to fit one.
