Using a second computer case as an external SCSI enclosure
Guest
Hi All,
I have an ancient computer that's just collecting dust on my network,
and I'd like to use it as an enclosure to hold (and power) a few SCSI
devices, one DVD burner and two hard drives. It will be connected
to my primary system with proper cabling (an interior-exterior SCSI
cable adapter, etc), and the devices will be run off the exterior SCSI
port on the controller in my primary system.
My question has to to with the Sparkle (SPI) FSP300-60GT power
supply in this secondary machine. I know these supplies require a
minimum load on certain rails, although I have no idea which rails,
and what voltage is required on each.
If I use this supply to run the three SCSI devices, but don't connect the
motherboard or any other power leads, will this be enough to satisfy
its minimum load requirements?
I hope I've described my question clearly, and I appreciate any help
or info.
Jeff
Baron
Hi All,
the motherboard or any other power leads, will this be enough to
satisfy its minimum load requirements?
or info.
Jeff
Short answer. Yes ! You will need to ground the PS (Green wire) to turn
it on. Or any older AT PSU with a real mains switch. In which case
you will need to load the 5V to draw about an amp.
Hi All,
or info.
Jeff
Either MCM (MCMinOne.com) or newegg has a power supply test load for a
couple of bucks. Attach it to the 20 or 24 pin mainboard connector and
it will take care of the problem.
Baron
Michael said:
They are not meant to be used on a continuous basis. They get too
hot
to touch in under a minute, and every one I've seen says not to use
for more than one minute at a time.
I agree ! You could cook eggs on my 120w test load within a few
minutes... Great on a cold morning though. :)
Eeyore
Hi All,
Chances are that the 5V and 12V loads will be fine.
or info.
Yes, it's been done before. Just a storage subsystem.
Graham
