Using capacitors in bridge t-type
pump
Nov 4, 2011
24
Hope somebody could help me explain this from the circuit below.....What effect do the capacitors have?
You may have to try posting the image or link again...
pump
Nov 4, 2011
24
Thanks will try again
pump
Nov 4, 2011
24
Not sure but my first thought is that the configuration will only attenuate under a certian frequency. If over this frequency then te signal will not get attenuated?
Is that correct?
:confused:
poor mystic
Apr 8, 2011
1,106
The circuit looks incomplete to me; I think that in order to understand it you need to consider the load, which will be most easily modelled as a pure resistance across the right hand side of the circuit.
Now we see that the capacitors are in series with the load, so that they have a "high pass" characteristic.
pump
Nov 4, 2011
24
Thanks for your reply poor mystic,
Yes that circuit is incomplete I removed the load just for the picture. So my thoughts were correct. At high frequency the input signal will not be attenuated?
As has been suggested, the load is all-important.
If the impedance of the load is high enough, the circuit won't attenuate anything at all.
The lower the load impedance the lower the frequency the 3db point moves.
Laplace
Apr 4, 2010
1,252
My analysis of the circuit is in the attachment. The node equations are on the first line. These are manipulated into a transfer function of the form, 20log(Vout/Vin). For the graph, component values selected have Rp=Rl so for very low frequency or DC input, Vo/Vi=0.5 or 6dB. Very high input frequency passes through the capacitors without attenuation, or 0dB. The depth of the notch seems to be related to the value of Rt.
  • MathCad_EP-11.pdf
pump
Nov 4, 2011
24
Laplace thank you for the explaination. Thats quite a bit of work you have put in there :)
Thank you all for helping me understand this circuit. Sometimes reserching by yourslef isn't enough, by speaking to people like yousleves and having it explained in plain English is whats needed. Thanks again for all your help
