Using Ultra Capacitors to Replace Batteries
D from BC
Ultra capacitor example:
http://www.elna.co.jp/en/ct/pdf/DZNe.pdf
10F
2.5V
18mm x 35mm
About $30.00 at digikey.
Question is.... Are these ultracaps replacing batteries in some
designs?
Maybe implemented in a cordless optical mouse or Mp3 player?
Can ultracaps outperform batteries?
D from BC
Damon Hill
10F
2.5V
18mm x 35mm
designs?
Depends...capacitors can have high power density (they can deliver
large amounts of current for a short time) but only very small amounts
of current for longer periods. Batteries have high energy density,
delivering small to medium (and sometimes high) currents for much
longer periods.
If the current drain is >very< small, they can replace batteries in
some instances; otherwise they can supplement batteries. Capacitors,
properly designed and used, can endure constant and high charge/discharge
rates, which batteries don't like.
If ultracaps could operate at substantially higher voltages, they
could store much more energy but probably never as much as batteries.
Both capacitors and batteries are improving, so I think we'll see more
of both being used, often in tandem.
--Damon
V
Vladimir Vassilevsky
10F
2.5V
18mm x 35mm
The energy density of a common alkaline battery is 1000 times higher,
and the cost is 100 times lower.
designs?
Only as a short term power source.
1000 times is too much of a difference.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
Spurious Response
longer periods.
--Damon
Good answer.
Gary Tait
10F
2.5V
18mm x 35mm
designs?
Maybe. Either for backup, or where their discharge is not critical.
I have seen them used for RTCs, and in some shake flashlights.
Nope. Li-Po batteries can do those.
Eeyore
10F
2.5V
18mm x 35mm
designs?
Not to *replace* batteries, no.
Not normally, although the ultra caps used in regenerative braking systems in
electric vehicles have the advantage of being able to accept charge faster than
a battery will.That's the only reason they're there.
Graham
Gary Reichlinger
Yes and no. They cannot store as much energy, but they can
charge and discharge much faster. There are certainly applications
where an ultracapacitor could replace a battery. I have considered
using them for a low drain application where they could be instantly
recharged by plugging (very) briefly into an automotive power supply.
It would require a capacitor with a low leakage current.
A more come design would be to use both. Alkaline batteries can
lose their charge very fast if they are subjected to a heavy current
drain even for a short period of time. Using a capacitor along with
the battery can extend the battery life since the capacitor can handle
the large but short high current requirement.
AZ Nomad
bullshit.
Your typical ultracap can only push few milliamp. Fine for holding CMOS memory,
but you're not going run a UPS.
To charge a farad in under an hour requires the ability to push a few amps.
Guy Macon
Content-Transfer-Encoding: 8Bit
It has been a few years since I used ultracaps, so somebody please
correct me if this is no longer true, but when I used them the
ESR was *very* high and thus the available current was quite low.
The combination of a large capacitance and a high ESR made it so
that I couldn't put a newly-built PWB on a test fixture and test
the board's ability to hold data during a power failure -- the
test was over before the ultracap had time to charge. I had to
add a test to the burn-in fixture. Likewise on the discharge;
short it out for a minute or so and find that it is still charged.
Wikipedia has an interesting energy density chart:
[ http://en.wikipedia.org/wiki/Energy_density ]
A few selected items from the list:
ENERGY DENSITY IN MJ/kg:
Spring...........................................0.0003
Capacitor........................................0.002
Supercapacitor...................................0.01
Ultracapacitor...................................0.02
Lead-acid battery................................0.09–0.11
EEStor Ultracapacitor (claimed capacity).........1.0
NiCd Battery.....................................0.14-0.22
NiMH Battery.....................................0.22
Zinc-air Battery.................................0.40-0.72
Lithium ion battery..............................0.54–0.72
Wood.............................................6.0–17.0
Flywheel........................................l0.5
Lignite coal....................................14-19
Cowdung/Cameldung...............................15.5
Methanol........................................19.7
Ethanol.........................................30.0
Anthracite coal.................................32.5
LPG.............................................34.39
Diesel fuel.....................................45.8
Gasoline........................................46.9
Hydrogen.......................................143
Uranium-235 (nuclear fission)...........90,000,000
Hydrogen (nuclear fusion)..............300,000,000
H
Hal Murray
That's what I would have said a few months ago. But a friend
gave me a heads-up. They are now competing with batteries
for things like electric cars.
http://www.worldandi.com/subscribers/feature_detail.asp?num=23938
Known for storing a short-lived jolt of electricity
essential to the successful operation of electrical circuits
in devices and appliances ranging from PCs to microwave ovens,
cell phones, and televisions, the capacitor is in the midst of
a major, ongoing upgrade of its energy storage capabilities.
After nearly two centuries in which batteries have been the
obvious choice for storing usable amounts of energy, high-end
capacitors, known as ultracapacitors, are poised to challenge
them in a growing range of applications.
http://www.technologyreview.com/NanoTech/wtr_16326,303,p1.html
A breakthrough technology is holding forth the promise of
charging electronic gadgets in minutes, never having to replace
a battery again, and dropping the cost of hybrid cars. Indeed,
the technology has the potential to provide an energy storage
device ten times more powerful than even the latest batteries
in hybrid cars -- while outliving the vehicle itself.
dav1936531
Has anyone actually had a production or product sample from EEStor. I
hear about this "unbelievable" capacitor technology they "have", but I
am wondering at what stage of developement these guys really are in.
I have a product that desparately needs their device (if it works as
rumor says), but have yet to see anything concrete from them. They
don't even have a web site.
Eeyore
They don't have a product yet AIUI.
Graham
Spehro Pefhany
Weeelll.. not all such devices are created equal, such as these $1900
babies:
http://www.globalspec.com/FeaturedP...260048_BOOSTCAP_Ultracapacitor_Module/28081/0
Here's more detailed specs on another module from the same
manufacturer:
http://www.maxwell.com/ultracapacitors/products/modules/bmod0018-390v.asp
17.8F, with max current 950A at 390 volts, which is more than 370kW.
Applications:
* Regenerative Braking
* Torque Assist Systems
* Engine Starting
Best regards,
Spehro Pefhany
amdx
Another EEstor Ultracapacitor story.
http://www.technologyreview.com/Biztech/18086/?a=f
Mike
SP
1 Farad charges at 1V per second at 1 amp.
Please watch your attributions. I did not write any of the above.
Best regards,
Spehro Pefhany
John Devereux
Sorry, I thought I had done so... You quoted AZ, and I quoted you
quoting him (I think).
I could not access the original post, so I replied to yours.
Anyway, sorry for any confusion.
Gary Reichlinger
bullshit.
As others have indicated, you are behind the times. Current
products do handle high current pulses.
Damon Hill
systems in electric vehicles have the advantage of being able to
accept charge faster than a battery will.That's the only reason
they're there.
Another important difference between batteries and capacitors
is the flatness of discharge voltage; a battery is nearly flat
over most of its range. I don't think a capacitor, no matter
how large, will be remotely as flat. This has interersting
implications in motor controller designs, for example.
--Damon
