using mosfets
casdsys
Ok I know how to use a transistor to turn a device on and off.
Could some one show me how you do the same but with using a mosfet.
I wish to use ttl level logic to turn on a mosfet.
martin griffith
OK who wants to start this time?
martin
Stanislaw Flatto
S.O.S (same old s**t).
Your controling driver sends signal to a device which changes its
resistance. So look at the data sheets and adjust the drive accordingly.
Have fun
Stanislaw
Slack user from Ulladulla.
PeteS
What load?
Most small signal /switching MOSFETS will operate with TTL levels (and
LVTTL levels), but much depend on the load (of course, it's easy to
control a larger switch with a small one).
However, you say you know how to use a transistor (one must assume a
bipolar) to turn a device on and off. The principle using a FET is much
the same. I recommend some data sheet reading. (Try the 2N7002 for a
start)
Cheers
PeteS
Luhan
A couple weeks ago, I bought some mosfets - never used them much
before. I found a use for one running my Dremel tool....
http://members.cox.net/berniekm/dremel.html
Now I see why they are so popular!
Luhan
Phil Allison
** Groper Alert !!!!!!!!!!
** No problemo.....
Just use a "logic level " mosfet.
The catalogues are full of them.
........ Phil
