Using phone mp3 jack for power.
khofo
Sep 3, 2014
9
Hey guys,
I was thinking lately about this and wanted some advice amd guidelines.
So what I want to do is use an mp3 cable connect it to the 3.5mm jack and when music plays r the phone rings the current in the cable is converted to DC and I can use it for whatever I want to power.
So is this possible?
And if yes any help or explanation of what I need
Gryd3
Jun 25, 2014
4,098
Yes and No.
The AC power delivered down that line is more for a signal, or driving headphones. Even if you build a circuit to rectify it to DC to store, there is such little power available that you will be severely limited to what you can power.
Remember that this is not free power, it may be a better option to pull power from the USB plug on a phone. Many Androids support USB OTG which can provide some power. Or you can use the accessory dock on an iPhone or other iDevice for power.
What are you trying to accomplish?
khofo
Sep 3, 2014
9
Yes and No.
Basically what I am trying to do is for example connect it to a small DC motor or a small relay so when it rings a circuit is activated. But the said circuit won't need the power of the mp3 but will use the battery built in. a sort of long range remote for me. Since radio or ir much much less effective.
Gryd3
Jun 25, 2014
4,098
This can be done. The small audio signal in the MP3 jack as you put it (Usually 3.5mm) can be detected and used to trigger a relay, motor or almost any other device. This will require a custom circuit to be built and cannot be powered by the phone's MP3 jack.
khofo
Sep 3, 2014
9
This sounds a little noobish. But what kind of custom circuit should it be. If u can point out the basic functions of this circuit and it's role, I'do my research and sort it out then :)
And thanks a lot
Gryd3
Jun 25, 2014
4,098
Ahh . you just want tips to go off yourself then?
That works out well. I can't draw anything up at the moment.
You're going to need to amplify the signal. Take a look at opamps for this portion.
Once the signal is amplified, you can use it to trigger a latch if you want your device to stay on, or a 555 timer if you only want it to stay on for a moment
khofo
Sep 3, 2014
9
Okay, thanks a lot for the advice. I guess I'll be having a great time on this forum
Gryd3
Jun 25, 2014
4,098
I enjoy it. There are plenty on here with tons of knowledge.
Im hoping to leach some from them myself ;)
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
First check that your phone will ring through the headphones. With some phones, when a call or text arrives when headphones are plugged in, the phone will just mute the headphones and play the ringing sound through the speaker.
Assuming the phone will send the ringing sound to the headphone socket, you need some kind of "envelope detector" - a circuit that detects an audio signal coming from the headphone output of your smartphone and activates a relay or power MOSFET.
Here's a simple solution with a couple of advantages: no power supply is required, and isolation is included.
This circuit uses an audio transformer, T1, to boost the (relatively) low-voltage audio signal from the headphone output of a cellphone or similar portable audio device to a voltage that's high enough to switch a MOSFET (Q1).
Headphone-level audio from the portable audio device is fed through a stereo jack-to-jack cable to input socket CN1. The left channel (the "tip" connection) feeds into T1, an audio transformer, which is used "in reverse", with its secondary driven, so that instead of boosting current, it boosts voltage.
Its output is rectified (converted to DC) and boosted by the "voltage doubler" or "charge pump" circuit formed by C1, D1 and D2, and a voltage is developed across C2 that depends on the amplitude (volume level) of the audio signal. R1 ensures that C2 discharges (over a period of a few tenths of a second) when the signal stops, and D3 limits the DC voltage to prevent possible damage to MOSFET Q1.
This circuit will probably cause audible distortion on the audio signal at the headphone output, so it probably won't be suitable if you're also using the headphone output as an audio source. This circuit only uses one channel though, so you might be able to use the other channel for audio purposes.
MOSFET Q1 is controlled by its gate-to-source voltage, which is equal to the C2 voltage generated by the audio signal. Various MOSFETs are suitable here; I've suggested the NTD4906N because it's cheap and has excellent specifications (apart from its voltage limit - it is only rated to switch 30V absolute maximum), but it's not widely available (it is stocked by http://www.digikey.com and http://www.mouser.com). Many other alternatives are suitable and any N-channel enhancement-mode MOSFET will work. For example, for low-power switching, BS170 or 2N7000 are suitable.
Q1 switches the output circuit. The "output" of this circuit is not a voltage; it must be inserted into a DC circuit to switch that circuit ON and OFF. It must be connected into the external circuitry with the polarity shown. If it is connected with the opposite polarity, the body diode in Q1 will conduct and the circuit will be permanently ON.
There are two caveats. First, the MOSFET is not switched ON and OFF quickly and cleanly, so it can dissipate significant power during the transitions from fully OFF to fully ON and vice versa if it is being used to switch a high-current and/or high-voltage circuit. In this case its SOA (safe operating area) parameters could be exceeded, in which case it will expire instantly, and/or it may get hot. If you're not sure, describe the load you're switching and ask for advice.
Second, the MOSFET is not protected against high-voltage spikes caused by "back EMF" or "inductive kickback" from inductive loads. Although such spikes will be minimised by the slow turn-OFF of the MOSFET, they could still cause problems, so if the load is inductive (e.g. a relay coil, a solenoid, or a motor), a diode should be reverse-connected across the load to clamp its back EMF voltage and protect the MOSFET.
The major requirement with this design is ensuring that sufficient gate-source voltage is generated to turn the MOSFET fully ON. This depends on (a) having a strong enough audio signal from the headphone socket, and (b) having a suitable turns ratio in the transformer, T1.
T1 should ideally have a turns ratio between about 5:1 and 10:1. This corresponds to an impedance ratio of between 25:1 and 100:1. (Transformers are often specified by their impedance ratio, not their turns ratio; the impedance ratio is simply the square of the turns ratio.) Here are a few transformers I found on Digi-Key that look suitable. Remember, these transformers are used in reverse - the audio from the portable device's headphone output drives the winding that is nominally called the secondary. In order of increasing price:
Tamura MET-28 1kΩ:50Ω encapsulated USD 11.07
http://www.digikey.com/product-detail/en/MET-28/MT4149-ND/285666
Turns ratio 4.47.
Tamura MET-35 600ΩCT:8Ω encapsulated USD 11.20
http://www.digikey.com/product-detail/en/MET-35/MT4153-ND/285670
Turns ratio 8.66 if you use the full winding on the circuit side. This one looks like a good choice.
Tamura MET-17 10kΩCT:500ΩCT encapsulated USD 13.44
http://www.digikey.com/product-detail/en/MET-17/MT4147-ND/285664
Turns ratio 8.94 if you use the centre tap and one end on the headphone side, and the full winding on the circuit side. Looks suitable.
Triad SP-33 1kΩ:50Ω encapsulated USD 16.30
http://www.digikey.com/product-detail/en/SP-33/237-1144-ND/242666
Turns ratio 4.47.
Triad SP-48 7.5kΩCT:12Ω encapsulated USD 17.37
http://www.digikey.com/product-detail/en/SP-48/237-1146-ND/242668
Turns ratio 12.5 if you use the centre tap and one end on the circuit side. Looks suitable.
Triad SP-29 10kΩCT:500ΩCT encapsulated USD 18.90
http://www.digikey.com/product-detail/en/SP-29/237-1143-ND/242665
Turns ratio 8.94 if you use the centre tap and one end on the headphone side, and the full winding on the circuit side (same as the Tamura MET-17).
Triad SP-5 50kΩCT:1kΩCT encapsulated USD 19.97
http://www.digikey.com/product-detail/en/SP-5/237-1138-ND/242660
Turns ratio 14.14 if you use the centre tap and one end on the headphone side, and the full winding on the circuit side.
I have only done cursory checks on the above listed transformers. I have not checked their power-carrying properties.
You may also be able to scrounge a suitable transformer from the output stage of an old transistor radio. These transformers have a centre-tapped "primary" (connect the ends of this winding to the circuit) and a "secondary" (connect this to the headphone signal).
In any case, you can test whether your transformer is suitable by measuring the DC voltage across C2 in the circuit. It should be less than 1V when there is no audio coming from the headphone output of the portable audio device, and should be at least 10V when audio is present, or a lower voltage if you use a MOSFET specified for "low VGS" or "logic level gate". These MOSFETs conduct almost fully with gate-source voltages of only 5V, sometimes lower. The NTD4906N is one such device; 5V gate-source voltage is enough.
If you can't get enough voltage, try increasing the volume setting on the device. If that doesn't work, you need a transformer with a higher turns ratio.
Good luck!
Gryd3
Jun 25, 2014
4,098
Oh wow. Good call on the transformer. Some of the things you pull out of your hat are pretty sharp Kris.
Khofo, you make stuff from recycled parts, right?
If you salvage mosfets and know how to store and identify them, you may be able to salvage something useable without a lot of effort.
The transformer may be somewhat harder to salvage. Few circuits use them as their cost is greater than another transistor stage to lower output impedance.
khofo
Sep 3, 2014
9
Turns ratio 4.47.
Turns ratio 4.47.
Good luck!
Well Thanks a lot for all these clarifications it will save me ton of research and headaches.
I'll try of course to salvage parts but I do not having any problem buying them as long as they are available here in Lebanon. And thanks
