Using transistors as SPDT switch?
Jon Danniken
I would like to build the switch in the following circuit using small signal
transistors:
5V +-------+ +---- GND
o /o
o
| | LOAD
12V ---------+
Any tips on how to go about this with a few discretes would be most
appreciated.
Jon
John Larkin
transistors:
5V +-------+
___
diode / \
| d
.-. nfet | |-------ctrl
| | or npn | g
| | LOAD --
'-' | s
| gnd
12V ---------+
It's easier to visualize stuff like this if it's drawn with the
current flowing down, namely with the +12 at the top.
John
Jon Danniken
Sorry 'bout that. Thanks for the help; that is a very nice and simple
solution.
Jon
Le Chaud Lapin
In this circuit, it looks like current passes through the load in both
the ON and OFF positions. Assuming an N-channel enhancement mode FET:
When switch is closed with application of Vg > Von to gate, FET does
not have opportunity to conduct do to exponential characteristic of
diode limiting drop to ground to approximately 0.7v, so current through
load is [12-Vdiode)]/Rload.
When switch is open with application of Vg < Von to gate, FET is off,
and current through load is [12-Vdiode]/Rload.
Assuming NPN BJT insted of NFET, you would also have to limit current
through the base-emiitter diode.
Depending on your load, which probably has relatively high resistance,
I don't see what a FET with a low Rds(On) wouldn't work.
-Le Chaud Lapin-
Jim Thompson
John
Just pretend you're a Physicist ;-)
...Jim Thompson
John Larkin
When the fet is on, the diode is back-biased and out of the circuit.
The fet saturates as well as it can, so current is (12-Vsat)/Rload or
maybe 12/(Rload+Rdson).
No, the current is (7-Vdiode) / Rload
The 5 volt supply does need to be able to sink Iload.
John
Le Chaud Lapin
I thought the same thing until I noticed that the OP has a GND
separating the 5-volt branch from the rest of the circuit, which if
meant to be present, would make that part of circuit irrelevant, hence
chance for misinterpretation.
I guess it would help to know whether the GND was meant to be there or
not.
-Le Chaud Lapin-
John Larkin
...Jim Thompson
Or an arabic engineer, with signals flowing from right to left!
I like to draw with positive supplies high on the page, and current
flowing down. That places PNP emitters up and NPN emitters down.
Signals flow to the right, feedback to the left.
John
John Larkin
not.
-Le Chaud Lapin-
I think it's a font problem. I think he meant...
o /o
o
| | LOAD
12V ---------+
John
Jon Danniken
o /o
o
| | LOAD
12V ---------+
Yes, that is what I had meant to paste in originally, thanks.
Jon
Jim Thompson
On Sun, 26 Nov 2006 15:09:34 -0700, Jim Thompson
[snip]
...Jim Thompson
John
Same here, actually. I was just yanking your chain ;-)
I'm really picky about schematic format... I like to draw so that it's
quite obvious how signals flow and how circuits work.
So I spend quite a lot of time cleaning up drawings to avoid clutter
and confusion.
...Jim Thompson
Le Chaud Lapin
An n-channel enhancement-mode FET pesents a conducting path when a
positive voltage is applied to its base and presents an open circuit
when the applied voltage is zero.
A p-channel depletion-mode FET presents an open circuit when a positive
volage is applied to its base and presents a conducting path when the
Take these two devices, tie their drains and together and attach the
drains to the oad. Tie their bases together to receive control signal.
Tie one source to 5V, the other to GND.
-Le Chaud Lapin-
