UV lamps vs corona discharge...
K
KILOWATT
Hi everyones...thanks for your time. I wish to make a large ozone generator
and i'm wondering if one of those two methods (see subject line) produces
less byproduct (like nitrous oxyde) than the other ? Maybe i'm wrong and
pure oxygen MUST be used to not have any byproducts...not shure. Any
comments? TIA for any replies.
Alain(alias:Kilowatt)
Montréal Québec
PS: 1000 excuses for grammatical errors or
omissions, i'm a "pure" french canadian! :)
Come to visit me at: http://kilowatt.camarades.com
(If replying also by e-mail, remove
"no spam" from the adress.)
Don Klipstein
I surely think that 184.9 nm UV produces more ozone and less NOx than
coronas, sparks/arcs, etc...
Do not confuse 184.9 nm, the shorter and secondary of the two main
shortwave UV wavelengths of a low pressure mercury discharge, with 253.7
nm which is the main one but basically useless for intentional ozone
generation. The main application of 253.7 nm is germicidal use.
CWatters
Just be aware that ozone is a lung irritant and levels used to clean air
(for example) are a hazard to health. Very bad for you if you have asthma
etc. I believe it also effects some rubber and plastic insulation.
Michael
Yes. Ozone is absolute murder on rubber. And lungs.
Eric R Snow
Ozone is indeed a major cause of rubber deterioration. Latex is
especially affected.
ERS
Ban
ERS
Also be aware that if your ozone generator reaches 12% purity, it will
explode. :-((
You will indeed need pure oxygen for levels above a per cent or so.
Lord Garth
ERS
Makes me wonder what sort of rubber is used on TV remotes...
I assumed it was silicone rubber but there is usually an oily
residue under them, probably from deterioration of the rubber.
