Simple lamps circuit
Romano
Sep 9, 2022
7
Hi dear friends.
I am a beginner in electronics. I am trying to make a circuit with the following characteristics:
Please, see the gif attached.
Functionalities
1 - when switch 1 is activated, lamp 1 flashes and lamp 2 remains on, even after releasing the switch.
2 - even if switch 1 remains pressed, lamp 1 does not flash again and lamp 2 remains on.
3 - If switch 1 is pressed again, lamp 1 does not flash again and lamp 2 remains on.
4 - Switch 2 resets the system, allowing switch 1 to make the lamp flash again and turning on lamp 3.
Could someone help with this project? I need to learn how to do it. If it takes to many time to do, would like to pay for any help, project or lesson.
Thanks, dear friends.
Nanren888
Nov 8, 2015
622
What's your starting point?
The switching seems ok. What do you know of switches?
There is a time element involved, as one seems to flash.
What do you have that might be able to change with time after being turned on?
danadak
Feb 19, 2021
1,104
You basically have to create a state machine, which you have in essence in words.
Then either translate that into discrete logic or a processor.
Question have you ever written any programs ?
Regards, Dana.
Romano
Sep 9, 2022
7
Hi Naren, thanks by the answer!!!!!
I know almost nothing about switches. I have already used simple switches and switches with two positions, but I’ve never combined two different switches. I think I can assemble a thee way switch in the wall, that can allow me to turn off a light bulb from two different switches, that’s all I know about switches.
About the time. The lamp 1 needs to stay on for 15.6ms. No, it does not need to be changed after the project is assembled.
Thanks, my friend.
Hope you are referring to low voltage lamps here.
Microcontrollers were made for such things.
Arduino forum would be a good place to start, along with some basic gear, clones micros are fine.
Suggest you stay well away from mains power.
Romano
Sep 9, 2022
7
Regards, Dana.
Hi, Dana, thanks for the answer!!!!
No, I have never done it. I thought about to read a little about Arduino, but I thought it would be wiser to ask here before, once it could exist a switch with this functionality, avoiding me to need complex circuits. I would like to keep it as simple as possible.
Regards, thanks!
danadak
Feb 19, 2021
1,104
Consider doing this project first with LEDs as lamps first, then get advice/learn
how to wire up a lamp to mains, and use relays to manage switching them on/off.
Regards, Dana.
Not good advice given the Op has admitted they know next to nothing about electronics let alone mains supply.
Romano
Sep 9, 2022
7
Regards, Dana.
Hi, Dana.
It will be a led project. Is there relays that could perform these effects? Witch should I type on Google to find information about these relays?
Romano
Sep 9, 2022
7
Guys.
How much it would cost me to have a circuit project like that? Someone could do it? It will be powered by 1,5v batteries.
danadak
Feb 19, 2021
1,104
What tools do you have, a vollt/ammeter, a soldering iron, a breadboard......?
Romano
Sep 9, 2022
7
Yes, Dana. I’ve all the tools needed at disposal. But, I really need the schematics.
danadak
Feb 19, 2021
1,104
Is this a student exercise ?
I suggest using Arduino Nano or Uno board. You would hook up leds
to port pins like this :
Use a R of ~ 170 ohms.
Then use mBlock to code the Arduino.
Here is a training video -
Regards, Dana.
