Value of RF (feedback resistor formula)
qwerty22
Nov 10, 2013
I need help as I have the answer but I don't know the formula
its an 741, with vi 1Vpp, input resistor is 10k, Value of output signal 10Vpp
I have to work out RF which is 100k, I did the usual **** 1vpp = 10k
10 vpp=10k x 10= 100k
But not the proper formula so I though this:
AV ( idk what it is) = 10v/1v = RF/10k =10
so RF = 10k*10 = 100k
Is that the formula? i need to show proper formula as working out, which i don't know,
however the answer is correct...
I can't seem to find the formula online anywhere btw.
Laplace
Apr 4, 2010
1,252
Instead of trying to find the correct formula, why not derive it yourself? Just realize two facts:
1. When the 1 Vp-p input is at +1V the 10 Vp-p output is at -10V.
2. The '-' input to the opamp is a virtual ground. The '+' is tied to real ground and negative feedback keeps the '-' input at the same voltage as the '+' input (within a few microvolts).
attachment.php
So what you have there is a simple voltage divider where 11 volts is divided between Rin and Rf. Solve that and you have the correct formula for finding Rf.
