Adrian Tuddenham
- Jan 1, 1970
- 0
I have been commisssioned to design and build a one-off audio
preamplifier using E88CC / 6922 valves in most of the signal-handling
stage. (Don't ask why - it is a strange project but definitely not
intended to be a piece of cult audiphool gear)
It has to meet an exacting spec for several parameters, including noise.
I was experiencing great problems measuring the noise by means of my
workshop bench amplifier because, as I increased the system gain,
various forms of instability began to manifest themselves.
At first I thought the problem was caused by V.H.F. instability in two
of the stages which were connected as cascodes; in that mode, high gain
is maintained to several hundred megacycles and some of my wiring was
long enough to have an appreciable effect at those frequencies. I was
already using a grid stopper on the bottom triode of the pair, but,
unconventionally, I found that another grid stopper on the upper triode
was necessary to cure the problem. H.F. oscillation in the HT PSU
(which was transistorised) was found to be another cause of some
unpredicatable behaviour - but there was still another effect which
remained:
This third effect depended on the gain of the whole system, the
amplifier on test plus the bench amplifier. The bench amplifier has a
monitoring loudspeaker, with an audio gain control independent of the
main calibrated measuring attenuator; the effect was found to vary with
the setting of this volume control. When the volume was advanced
slowly, there was a pause, then the level meter slammed hard over. As
the control was turned back, after a few seconds, the meter dropped
back. The effect was just like audio feedback in a very high-Q
situation.
Eventually I came to the conclusion that this really was audio feedback,
but in the ultrasonic range. I found I could alter the oscillation
point by covering the loudspeaker with my hand. If I tapped one of the
valves with a small hard object, I could send the meter off-scale -
although very little sound was audible through the loudspeaker. An
oscilloscope showed oscillation building up at 37.5 Kc/s
Presumably the short, robust, electrode structure of these VHF triodes,
which were never intended for audio work, has a high-Q mechanical
resonance at ultrasonic frequency.
remained:
situation.
