Variable power supply LED indicator
piczim
Dec 13, 2012
23
I have put together a variable power supply between 1 and 30Volts, Included on the output is an on off switch, I want to incorporate an LED to show when it is on, how do I go about this.
GreenGiant
Feb 9, 2012
842
is there only an on/off switch on the output?
We would need schematics or pictures at the very least to tell you for sure
The simple answer is a LED and an appropriate resistor running from the unregulated DC. But that makes assumptions that GreenGiant (perhaps justifiably) did not want to make.
A double pole switch comes to mind. Run the LED off the input to the regulator. But why would you only switch the output anyway?
