You came across something which was obviously a fuse or fuseholder
which you hadn't seen before. You knew the item you were asking about
on the unit was a fuse because it was marked so, and even had the
value and slo-blo written alongside it. The thing has a screw cap
which you removed so if this didn't give the clue that "duh, some type
of fuse must go in here". then no wonder other people are frustrated
at your posts.
So, before getting on the NG and posting did it occur to you to do
some research on the web, even if it was only to protect yourself from
ridicule because of your ignorance on the matter? By typing two words
"fuse fuseholder" (without the quotes) into Google would reveal in the
second picture a 3AG fuseholder similar to the one you had in front of
you.
http://www.allelectronics.com/cgi-bin/category.cgi?category=250
Clicking More Info on this item takes you to
http://www.allelectronics.com/cgi-bin/item/FHPM-31/250/3AG_PANEL_MOUNT_FUSE_HOLDER_.html
and it says "screw style cap" and "suits 3AG and MDL style". Now that
writing 3.2A SLO-BLO on your unit must refer to the fuse which goes in
it.
Browse by Category menu on the right would have revealed there were
separate categories for "Fuses" and "Fuseholders", so have a look at
Fuses.
http://www.allelectronics.com/cgi-bin/category/245/Fuses.html
Here we find a sub-category "MDL (Slow-Blow)" so that takes us to
http://www.allelectronics.com/cgi-bin/category/245300/MDL_Slow-Blow.html
Item 5 is the closest you will get at 3A so now you know all you
needed to before getting on the NG and posting.
Look first, and when you have done your research ask questions from a
basis of at least having done something yourself.
Now hang on a minute... You didn't tell us before now that you were
supplied the unit "without the fuse", so how was anybody supposed to
guess this fact. So, NO, it is not a reasonable assumption for us to
"guess" that it had "previously blown a fuse". Only yourself would
have been able to make that assumption. We aren't psychic you know...
Given the information you provided we had to assume (wrongly it now
seems) that you knew what a fuseholder was and the type of fuse to
use, and that you had powered it up but it didn't work. We assumed you
would have ensured there was a fuse in it since you had all the info
written on the unit. And since you didn't say that fuse blew, we
assumed that your problem related to continuity within the fuse. These
things are so obvious to us that we didn't think to ask "have you
tried a new fuse in the fuseholder?" because we thought you would have
done this already.
You are dead right there.... so why didn't you do it?
All right, we NOW know that you weren't aware that this style of fuse
holder used a tubular fuse but we couldn't guess that could we. After
all tubular fuses have been around since about 1930 and panel mount
fuseholders have been around for at least 50 years and anybody who is
even vaguely familiar with electronic equipment will have come across
them. The fact is you knew the object was a fuse because it was there
in white letters. It is obvious you must have unscrewed the cap and
found nothing there so pray tell me why this didn't prompt you to ask
yourself "now how can this fuse thing work when I have this completely
disconnected screw cap in my hand and there is nothing at all in it?"
Bloody hell, if it wasn't immediately obvious there was a bit missing
then your logic is non existent.
Try to imagine that you are asking for help "by remote control". We
can't see what you have in front of you so you have to describe it in
detail. Heck, if I hadn't dug up that pic of the power supply by
Googling nobody would have had much of an idea of what you were
talking about.
You seemed a candidate for a disclaimer because when it became obvious
you had never come across a panel mount fuseholder in your life. Then
it seemed possible you didn't have any electronics knowledge and you
might put yourself in danger by following suggestions. Anybody who has
dabbled in electronics in the last 50 years or more will have come
across this common type of fuseholder so it would have been highly
improbable that you hadn't seen one before.
What is a "flex metal" type fuse? I've never heard of it. What type of
"consumer electronics" are you talking about? Are you talking
whitegoods such as microwave ovens, washing machines etc? If so, you
are right, they don't have panel mount fuseholders. They don't want
ignorant people replacing the fuses when they don't know what they are
doing.
When whitegoods have a fuse it will usually be concealed inside but in
most cases that I have come across they are still tubular fuses either
ceramic or glass and generally size 3AG and mounted in an open style
fuse clip with a plastic insulating cover of some sort. A microwave
oven is a good example.
If you had given all the info to start with, and done some research,
you would have received the correct advice. Given the paucity of info
then you can't blame people for getting up your arse. The "hostility",
as you put it, came about because of frustration due to you not
providing all the info you had, or should have had, before posting.
