VCLFO question
darren adcock
Sep 26, 2016
463
Not quite sure how to word this correctly which is probably why I couldn't find what I needed off google
How do I change the sweep/voltage range on the cv out of VCLFO's, been trying to find a circuit, but think I lack the terminology to find what I need.
I've added a diagram in case I'm not making any sense here. The first diagram shows a triangle wave sweeping from -12v to +12v, the second shows a traingle wave sweeping fomr -6v to +6v.
I've attached the MFOS VCLFO circuit I am using also.
Thanks in advance
Darren
14,293
How about a simple resistive voltage divider? Vout = Vin /2 should do the trick.
darren adcock
Sep 26, 2016
463
Cheers Harald. That's simple enough, passive also. Now I understand why I'm gonna need a LOAD of CV mixers. ;-).... still new to this modular game
darren adcock
Sep 26, 2016
463
Following your lead I'm looking at this CV mixer with two op amp stages. Am I right in thinking that "offset function" means inverted and non-inverted outputs? If so (just jumping ahead here) it would be really good if both could be selected on a single pot.... if half rotation meant zero mix for either, but pot fully clockwise would mean maximum noninverted mix and fully anti clockwise meant maximum inverted mix. Is this possible? CV mixer with offset function.gif
14,293
Obviously, although that is not the classic definition of an offset.
The circuit is rather simple:
Potentiometer R3 is usd to mix the outputs of U1 (non-inverting) and U2 (inverting). An optional buffer amplifier may be used to decouple the output from the comparatively high impedance of the potentiometer.
darren adcock
Sep 26, 2016
463
In fact, been watching EEv opamp tutorials on youtube. Let me see if I can try and figure this out on 5SPICE first.
I doubt I'll be able to figure out a configoration for my Pot question but I'd like to see if I can figure out at least two op amp stages with desired voltage outputs +/- 5v with inverted and non inverted outs.
darren adcock
Sep 26, 2016
463
Well nearly got there in time before I couldn't resist looking at your circuit. Thanks. I'll work out how to change the values to match my system.
In future I'll try to simulate at least something before asking so I can push my learning.
cheers
Darren
darren adcock
Sep 26, 2016
463
Oh and thanks for the wiki link, tabbed to read later on at my workshop
