VDO Voltmeter
Post a complete schematic while you are at it.
Those fritzing things are useless.
JWHassler
Dec 22, 2014
86
I have a 6v vintage car. I want to add a voltmeter under the dash but 6v voltmeters are scarce. So I thought to add a voltage doubler inline before the gauge and adjust the gauge for any voltage loss. I’ve built a voltage doubler with a 555 chip and some bits and pieces. The doubler seems to work perfect on the bench with my multimeter. With a 6v battery and the doubler, the multimeter reads 11.5v. With a 9v battery and the doubler, the multimeter reads 17v. The car has a 6v generator and puts out around 7v which measures 12v with the doubler and using the multimeter.
Using the VDO gauge I get unexpected results. Not using the doubler, VDO reads the voltage correctly, 12v battery reads 12v. 9v battery reads 9v. However when using the doubler I get very low results. 6v battery and doubler read 8. 9v battery and doubler reads 11v. So my 7v car generator doesn’t barely register on the VDO which starts at 8v. So... why does the doubler show different results between the multimeter and the VDO gauge?
Automobile voltmeters draw more current than multimeters. Measure the current into your meter when it is connected across a reasonably stiff 12-volt source. That is the current for full-scale deflection, and what you must come up with by reducing the value of that 68-something resistor and connecting across a six-volt source
bertus
3,877
Then it must indeed be the 68.1 Ohms, wich is a valid value according E48, E96 or E192 series:
Bertus
