Velleman Voice Changer Mod
Rushmoore
Jun 21, 2015
26
Hey there!
Before I begin, I confess that I am an electronics noob and I apologize for asking such stupid questions. Ahem. Ill begin:
So I want to use the velleman voice changer, the device modifies the speakers voice in real time, however I do not want this. I want to be able to record a message then press a button to hear the modified voice. How can I do this?
Martaine2005
May 12, 2015
5,317
Hi Rushmore, you should have really bought a voice recorder / module.
But you can get one of these.
And use it with your voice changer.
Martin
Rushmoore
Jun 21, 2015
26
Hey, Thanks for this :) Do you know how I could wire up the voice changer with the voice recorder?
Many Thanks :)
Martaine2005
May 12, 2015
5,317
Hi, what voice changer kit is it? Was it a kit version?
Mk171?
The above voice changer has a speaker output. The other unit I linked to has a line input and speaker output, So shouldn't be a problem getting them to work together.
Martin
Rushmoore
Jun 21, 2015
26
I think Ill use this one: https://www.quasarelectronics.co.uk/Item/velleman-mk195-voice-recorder-playback-kit
If I use this I won't have to use the voice recorder, it's not really a voice changer, but you can change the speed of the audio, which is fine for my needs. The next problem is that I want to use one speaker with both these devices:
http://www.amazon.co.uk/dp/B00QIW52...m=A3P5ROKL5A1OLE&pf_rd_r=05W17NVCQZ3H572Q8KFG
I need to be able to record my voice and also play pre recorded files, so I am going to use those two devices. Is using an amplifier the best way to do this?
Muchas Gracias
Martaine2005
May 12, 2015
5,317
The unit I linked to will do exactly what you want. One speaker to both units.
And also play pre-recorded samples / messages too.
The cheaper unit doesn't have inputs for pre-recorded files either.
De nada
Martin
Rushmoore
Jun 21, 2015
26
But this device doesn't let you store multiple sound flies does it? D:
Rushmoore
Jun 21, 2015
26
hehe that is true :D Well, thanks for helping me out :) Tis much appreciated comrade :D
