Verify a(maybe) dying diode caused by a bad capacitor???
I have just fixed an power supply by replacing a bulging capacitor.
The capacitor is connected to diode. And the diode becomes hot and
makes a black spot on the board since the faulty cap.
I check the diode with a multimeter and it tests great.
The repaired power supply( cap replaced) has been tested for several
hours and no problem yet.
Question: Is there any way to check whether the diode is working
100% ?
Thanks!
Charles Schuler
100% ?
Diodes are cheap. It was stressed. Replace it.
Meat Plow
100% ?
Mostly they either work or don't. Short or open. Spend a buck and
replace it.
100% ?
Thanks!
It seems like the repair worked, but the hot diode concerns me. Your
description is a little hard to understand. Did the diode get hot
before or after the capacitor was replaced?
In any case, the black mark by the diode isn't a good sign. Whether
the mark was cause by the diode overheating or leakage from the
bulging capacitor, I would replace it. As another poster tersely
pointed out, diodes are inexpensive.
For a definitive measurement, don't test the diode in place. Rather,
unsolder one of its leads from the circuit board and then test it with
your voltmeter's continuity checker.
-Dave
Jeroni Paul
By your descriptions it looks like your supply is working fine. It is
normal for some components to warm up and if it were faulty you would
see some problem with your supply. If it works, don't mess with it.
Sam Goldwasser
If it tests good in-place, it won't test bad when removed. :)
However, the inverse (??) may be true.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
Repair | Main Table of Contents: http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ: http://www.repairfaq.org/sam/lasersam.htm
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
Important: Anything sent to the email address in the message header above is
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Arfa Daily
I see lots of bulging caps in the power supplies of cheapo DVD players - I
probably repair 2 or 3 a week on average. I have found it very rare indeed
for the feeding diode to actually be faulty. Usually, it's just a case of
replace the cap, and that's it. It is not at all uncommon for the diodes in
these supplies to run very hot, and discolour the board. Sometimes, if there
is room, I bend a small piece of metal around the body of the diode, with a
bit of heatsink paste in there as well, to help cool it down a bit. Bear in
mind if you do replace it that it will be a Schottky type ( I'm assuming
that this is a switch mode PSU ??? )
Arfa
James Sweet
100% ?
Thanks!
Is the power supply being overloaded? If it's not and the output voltage
is correct, I wouldn't worry about a warm diode.
Eeyore
Bad advice.
Some components may have been stressed by the fault The charring near the diode
indicates this.
There's NO WAY to prove the diode hasn't had its reliability compromised through
overheating so it should be replaced as a precaution.
Graham
Eeyore
Arfa said:
Bear in mind if you do replace it that it will be a Schottky type
Or a fast-recovery type.
Using a standard diode will guarantee long term failure although it might work
for a bit.
Graham
Jeroni Paul
Eeyore said:
Bad advice.
indicates this.
The charring proves that the diode has always run hot and it is likely
the way it is meant to be. A board is not charred in just a few hours
of operation.
Messing and replacing these diodes is a good way to risk the power
supply, and given that it runs hot I would be very careful with the
type I replace it with, get it wrong and you may blow the supply again.
