Need your advance help to verify my design
KUMARA SHP
Aug 1, 2014
122
here is my ardiuno based motor control circuit
I feel all the things are fine
but please look at it and tell me your comment
Arouse1973
Adam
Dec 18, 2013
5,178
D1 is connected to nothing should this be connected to RAW? Why do you have the second voltage regulator? Does the Arduino not output 5 Volts on Vcc? Neaten up the wire from pin 13 going across the Arduino. All your circuit shows is a load of connections so yes it looks ok. But if you want us to check the whole design you will have to add the motor control circuitry to your diagram.
Adam
