verilog code
vead
Nov 27, 2011
473
please check out this verilog code for D flip flop
Code:
module d_flipflop (d,clk,q,q1);
input d;
input clk;
output  q;
output  q1;
reg q, q1;
always @ (posedge clk);
initial
begin
q = d ;
q1=~d;
end
endmodule
when I don't use initial statement. I show error. what is use of initial statement
It is used to stop you getting an error.
Another explanation is that it is syntactically a required element.
Another reason is that it clearly balances out the "endmodule" at the end.
Another reason is to give the routine a name that you can refer to and to identify the interface elements.
I think they're all pretty good reasons.
vead
Nov 27, 2011
473
verilog code for half adder
there are two type of code
Code:
module half_adder (a,b,sum,carry);
input a;
input b;
output sum;
output carry;
assign carry=a&b;
assign sum=a^b;
endmodule
and other code
Code:
module halfaddert_b;
reg a;
reg b;
wire sum;
wire carry;
ha uut ( .a(a),.b(b),.sum(sum), .carry(carry));
initial begin
#10 a=1′b0;b=1′b0;                       –This is input a=0,b=0
#10 a=1′b0;b=1′b1;                        –This is input a=0,b=1
#10 a=1′b1;b=1′b0;                        –This is input a=1,b=0
#10 a=1′b1;b=1′b1;                         –This is input a=1,b=1
#10$stop;
end
endmodule
In first code we are witting only equation while second code we are putting some value
what is difference between in this two code
Perhaps you should do some research on verilog syntax?
We're not google.
But google says this.
vead
Nov 27, 2011
473
I have google .actually I have seen two type of code, one where we write only equation and other where we put some binary value. I don't understand which one code is true why we use two type of code to write verilog code
if you can tell me the difference its good for me. I will do next step. I want to write code for encoder, decoder , multiplexer , de multiplexer please tell me which type of code I can write code 1 or code 2
vead
Nov 27, 2011
473
multiplexer 2 to 1
Code:
s  d1  d0  q
0  0    0    0
0  0    1    1
0  1    0    0
0  1    1    1
1  0    0     0
1  0    1    0
1  1    0    1
1  1    1    1
Code:
module ( s,d1, d0,q)
input s, d1, d0;
output q;
reg q;
always @( s or d0, d1);
begin
case (s)
1'b0 : q= d0;
1'b1 : q= d1
end case
end
endmdule
I don't understand two statement
1'b0 : q= d0;
1'b1 : q= d1
I tried in this way
1'b0 : q= d0
Code:
q  d0  s
0  0    0
1  1    0
0  0    0
1  1    0
0  0
0  1
1  0
1  1
Is it correct
