Very basic triac circuit problem:
MidAtlantian
May 12, 2015
36
I am trying to use a triac in a very simple circuit. My circuit uses a MOC3041 isolator to trigger a BTA316 triac. I can wire the 3041 with a 9v dc circuit and an external LED and then I can see that the 3041 is turning on when I power the internal LED. But when I wire the triac to the 3041 - one side (pin 6) to the triac's gate (pin 3) , and the other side through a 150 ohm resistor to the load side of the triac, and turn on the 3041, the triac does not switch on. I am sure this must be as fundamental an error as one can make, but, well, here I am!
Thanks for any suggestions,
MidAtlantian
What current are you running the LED in the optocoupler at? And can you show us the circuit?
MidAtlantian
May 12, 2015
36
Hi Steve,
I thought I had not posted this! I found my problem: I had the control loop going from the gate through a resistor into the load side of the triac. Wired to the supply side, it works fine. And yes, when the current through the LED was not high enough, that was a problem, but I'd got that far. :)
However, thank you or your response. As far as posting a schematic, I do not have any software that makes that easy. Are there any you'd suggest? Especiallya more or less intuitive one, that I might not have to spend a lot of time learning.
14,480
Paintbrush in Windows is as good as any for doing quick schematics
MidAtlantian
May 12, 2015
36
Paintbrush? Yes, I guess you build a "master page" that you add to up as you need and create symbols. Easy. thanks.
Digikey have an online schematic tool that I often use. You need to register for it but other than that it's free.
Google "digikey schemeit" for more information.
MidAtlantian
May 12, 2015
36
Dave,
Thank you!! That is quite a gift and saves me doing a lot of work. That looks like most of what I'd use.
Funny, it is "just" one page, but there is really a LOT of stuff - and a lot of work - in it.
MidAtlantian
MidAtlantian
May 12, 2015
36
Steve,
That looks helpful, especially as it has an index of symbols with their names. Often I'll know the name of a component but not the correct symbol, but also, sometimes I'll come across a schematic where I don't know what the symbol means, so that should be useful. However, I'm some distance from telephone exchanges or optical cables, and my internet is often VERY slow, so relying on a link is not the best for me, but this looks very good too. Thanks.
MidAtlantian
