VHDL Generic Coding
rob_croxford
Aug 3, 2010
262
Hi All,
I have recently been trying to get into VHDL coding for use on FPGA's. I have been designing an Encoder/Decoder type system for error coding.
I have a question which i hope someone will be able to shed some light on:
I have designed a 7/4 decoder and a 15/11 decoder however i wish to make this code generic in that it the single piece of code will work for both designs.
any help or pointers would be greatly appreciated.
code bellow: (7-4 decoder can also send 15/11 decoder if needed)
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
ENTITY decoder IS
PORT (clk : IN STD_LOGIC;
res : IN STD_LOGIC;
sin : IN STD_LOGIC;
dout : OUT STD_LOGIC_VECTOR(3 downto 0));
END decoder;
ARCHITECTURE behaviour OF decoder IS
SIGNAL control : STD_LOGIC_VECTOR(6 downto 0);
SIGNAL rxlss : STD_LOGIC_VECTOR(3 downto 1);
SIGNAL sipo : STD_LOGIC_VECTOR(6 downto 0);
SIGNAL error : STD_LOGIC_VECTOR(2 downto 0);
BEGIN
error <= sipo(6 downto 4);
PROCESS
BEGIN
WAIT UNTIL RISING_EDGE (clk);
IF(res = '1') THEN
control <= "1000000";
rxlss <= "000";
sipo <= "0000000";
ELSIF(res = '0') THEN
rxlss(1) <= (sin XOR rxlss(3) XOR rxlss(2)) AND NOT(control(0));
rxlss(2) <= rxlss(1) AND NOT(control(0));
rxlss(3) <= rxlss(2) AND NOT(control(0));
sipo <= (sin XOR rxlss(3) XOR rxlss(2)) & sipo(6 downto 1);
IF control(6) = '1' THEN
CASE (error) is
WHEN "001" => dout <= (sipo(3 downto 0)) XOR ("1101");
WHEN "011" => dout <= (sipo(3 downto 0)) XOR ("1010");
WHEN "111" => dout <= (sipo(3 downto 0)) XOR ("0100");
WHEN "110" => dout <= (sipo(3 downto 0)) XOR ("1000");
WHEN OTHERS => dout <= sipo(3 downto 0);
END CASE;
END IF;
control(6 downto 0) <= (control(0)) & (control(6 downto 1));
END IF;
END PROCESS;
END behaviour;
Best regards,
Rob
George_Myers
Nov 25, 2011
Rob,
Ive been working on this for you,
its almost full Generic just the bottom section that needs sorting to do with the error code
library IEEE;
use IEEE.std_logic_unsigned.all;
use ieee.numeric_std.all;
ENTITY GenDecoder IS
GENERIC ( a : INTEGER := 7;
b : INTEGER := 4);
PORT ( clk : IN STD_LOGIC;
res : IN STD_LOGIC;
sin : IN STD_LOGIC;
dout: OUT STD_LOGIC_VECTOR(a-b downto 0));
END GenDecoder;
ARCHITECTURE behaviour OF GenDecoder IS
SIGNAL control : STD_LOGIC_VECTOR(a-1 downto 0);
SIGNAL rxlss : STD_LOGIC_VECTOR(a-b downto 1);
SIGNAL sipo : STD_LOGIC_VECTOR(a-1 downto 0);
SIGNAL errorcode : STD_LOGIC_VECTOR((a-b)-1 downto 0);
BEGIN
errorcode <= sipo(a-1 downto b);
PROCESS
BEGIN
IF (res = '1') THEN
control <= std_logic_vector(to_unsigned(2**(a-1), (a)));
rxlss <= std_logic_vector(to_unsigned(0,(a-b)));
sipo <= std_logic_vector(to_unsigned(0,a));
ELSIF (res = '0') THEN
rxlss(1) <= (sin XOR rxlss(3) XOR rxlss(2)) AND NOT(control(0)); --Decoder
rxlss(3) <= rxlss(2) AND NOT (control(0));
sipo <= (sin XOR rxlss(3) XOR rxlss(2)) & sipo((a-1) downto 1); --Serial In Parallel Out
IF control(6)= '1' THEN --Assessor and Corrector
CASE (errorcode) IS
WHEN "001" => dout <= (sipo(a-b downto 0)) XOR ("1101");
WHEN "011" => dout <= (sipo(a-b downto 0)) XOR ("1010");
WHEN "111" => dout <= (sipo(a-b downto 0)) XOR ("0100");
WHEN "110" => dout <= (sipo(a-b downto 0)) XOR ("1000");
WHEN OTHERS => dout <= sipo(a-b downto 0);
END CASE;
END IF;
control(a-1 downto 0) <= (control(0))& (control(a-1 downto 1));
END IF;
END PROCESS;
END behaviour;
if you have any ideas about the rest it would be good to know
Regards
George
