Matt
- Jan 1, 1970
- 0
I am toying around with some GLUE logic to interface a 1655 to an
ISA bus. I have added my code below, however, when I try to synthesis
the code I recieve the following error:
"IRQ[0]" at isagluesimp,vhd (55) because is does not hold its value
outside the clock edge
I recieve that for all the IRQ lines in the IRQ vector. This error
goes away when I comment out the:
ELSIF (BCLK'EVENT AND BCLK='1' AND AEN='0' AND SA=address1 AND FLAG=
'0') THEN
line. ( I surrounded it in stars so it is more readable.
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
ENTITY gluesimp IS
PORT( SA: IN STD_LOGIC_VECTOR (19 downto
0); --system address lines
D: INOUT STD_LOGIC_VECTOR (7 downto 0); --data bus
IRQ: OUT STD_LOGIC_VECTOR (10 downto 0); --IRQ
vector. Only one pin is used depending on the IRQ selected
IO16: OUT STD_LOGIC; --when
addressed, IO16# is asserted
RSET: IN STD_LOGIC; --when
asserted, system has reset, all values return to initial state
IOR: IN STD_LOGIC; --when
asserted, the system is doing an IO Read
IOW: IN STD_LOGIC; --when
asserted, the system is doing an IO Write
BCLK: IN STD_LOGIC; --bus clock
from CPU board (8.33MHz) used as clk signal
AEN: IN STD_LOGIC; --when
asserted, address is invalid (DMA read in progress)
----------UART SIGNALS--------------------------------------
ADD: OUT STD_LOGIC_VECTOR (2 downto 0); --A2, A1, A0
used to select internal register of 1655
CHIPSEL: OUT STD_LOGIC; --CSA, CSB, CSC,
CSD chipselect for 4 different channels (ACTIVE LOW)
DATA: INOUT STD_LOGIC_VECTOR (7 downto 0); --Data register
for both input and output to/from card
ISR: IN STD_LOGIC; --Interrupts
from the 4 channels. These will be anded together
RD: OUT STD_LOGIC; --Read strobe
WR: OUT STD_LOGIC; --Write strobe
RESET: OUT STD_LOGIC); --Reset
--INTN: OUT STD_LOGIC; --Configurable
depending on the type of interrupts used (MAY NOT BE USED)
--TXRDY: IN STD_LOGIC; --If TX FIFO
buffer is full, this will be set (ACTIVE LOW, MAY NOT BE USED)
--RXRDY: IN STD_LOGIC); --If RX FIFO
END gluesimp;
ARCHITECTURE behavior OF gluesimp IS
CONSTANT address1: STD_LOGIC_VECTOR (19 downto 0) := X"002E8";
--declare base address vector for channel
CONSTANT interrupt: STD_LOGIC_VECTOR (10 downto 0) := "00000000001";
--declare interupt vector
SIGNAL FLAG: STD_LOGIC; --used to
inform the internal system an interrupt has been thrown
SIGNAL TRUEADDRESS: STD_LOGIC_VECTOR (11 downto 0); --contains
the usable address
SIGNAL TRUEDATA: STD_LOGIC_VECTOR (7 downto 0); --contains
the usable data
SIGNAL TEMP: STD_LOGIC_VECTOR (2 downto 0); --address
sent to the UART
BEGIN
PROCESS (BCLK, RSET, ISR)
BEGIN
FLAG <= ISR;
IF (RSET='1') THEN --RESET LOGIC
ADD <= "000";
CHIPSEL <= '0';
RESET <= '1';
RD <= '1';
WR <= '1';
IO16 <= 'Z';
D <= "ZZZZZZZZ";
IRQ <= "ZZZZZZZZZZZ";
FLAG= '0') THEN --I/O request from system
IO16 <= '0'; --inform the system that this
is an 8-bit board
TEMP <= SA(2 downto 0); --takes the base address away
for easier use
TRUEDATA <= DATA;
CHIPSEL <= '1'; --selects a
port
IF (IOR = '1') THEN --It is a read
RD <= '1'; --tells UART that it is a read
command
ADD<= TEMP; --sends register address to UART
D <= TRUEDATA; --data from the UART is
placed on the ISA data bus
ELSIF (IOW = '1') THEN
WR <= '1'; --tells UART that it is a write
command
ADD <= TEMP; --sends register address to UART
DATA<= D; --data from the ISA BUS is sent
to the UART
END IF;
D <= "ZZZZZZZZ"; --silence on the bus
IO16 <= 'Z';
ELSIF (FLAG = '1') THEN
IRQ <= interrupt;
IO16 <= '0'; --inform the system that this is
an 8-bit board
for easier use
port
command
D <= DATA; --data from the UART is placed
on the ISA data bus
command
to the UART
END IF;
IO16 <= 'Z';
END IF;
END PROCESS;
END behavior;
I thought this error occured if I tried to have another IF statment
using the NOT of a condition used in a previous NOT, but all my other
IF statements do not use the conditions of the line of code I
highlighted.
Any help would be great.
'0') THEN
LIBRARY ieee;
ENTITY gluesimp IS
END gluesimp;
the usable address
the usable data
sent to the UART
BEGIN
BEGIN
FLAG <= ISR;
ADD <= "000";
CHIPSEL <= '0';
RESET <= '1';
RD <= '1';
WR <= '1';
IO16 <= 'Z';
D <= "ZZZZZZZZ";
is an 8-bit board
for easier use
TRUEDATA <= DATA;
port
command
command
to the UART
END IF;
IO16 <= 'Z';
IRQ <= interrupt;
an 8-bit board
for easier use
port
command
on the ISA data bus
command
to the UART
END IF;
IO16 <= 'Z';
END IF;
END PROCESS;
END behavior;
highlighted.
