Virtual ground help
Here's what I have and here's what I need: I have a 12v source of virtually unlimited current (car battery). What I need is a way to easily and cheaply produce plus and minus approximately 5 volts (not critical) at about 3 amps for an automotive application. From here I have to drive an op amp to produce say plus or minus 3 volts to drive a transducer with will require at least 2 amps at full swing. I can do this by buying DC converter modules, but at this current level they're pricy. Doing some checking, I've come across "rail splitters", something I've never dealt with in almost 40 yearsof repairing electronics.
Any advice appreciated.
Edwin
Phil Allison
<[email protected]>
** Does this "transducer" require DC current or can it be AC coupled ?
You need to supply more info.
.... Phil
George Herold
<[email protected]>
Yup! More info.
I've done low freequency 'rail splitting' If your 2 to 3 amps of current is is being returned to the virtual ground, then the device that's making that 'ground' from 0-12 Volts will be dissipating 6V*3A ~18 Watts.
George H.
