Vishay resistor query - Red Black Gold Gold?
hifi_geek
Dec 5, 2017
6
Hi all,
I have searched everywhere but to no avail, so I am hoping that one of you can assist.
I need a replacement resistor for a project I am working on, and the coloured bands are red, black, gold and gold. I will upload a pic shortly, but in the meantime can anyone tell me where I can find the exact type? I know it's a Vishay but there are hundreds.
Thanks.
hifi_geek
Dec 5, 2017
6
kellys_eye
Jun 25, 2010
6,512
2Ω 5% - without some comparison for scale it looks like a 1/4 watt device, maybe 1/2 watt.
why do you want an 'exact' replacement?
Can't tell you how many times I have done a quick correction like that!
kellys_eye
Jun 25, 2010
6,512
Ditto - relying on 'instinct' doesn't work as often as it used to. Old age setting in......
hifi_geek
Dec 5, 2017
6
Thanks guys. Reason I asked is that some chaps on a different forum thought it was a 200 ohm version as it’s powering LEDs. But as you say the calcs bring it out as a 2 ohm one.
Ok so I got these, do you think they will suffice given the tolerance is not quite correct?
hifi_geek
Dec 5, 2017
6
Also the resistor is the same size in terms of scale as the one in the bottom photo as you can see it’s small! Thanks.
kellys_eye
Jun 25, 2010
6,512
The tolerance you actually have is better than what you're replacing it with - not highly important but better than a 'worse' tolerance.... so yes, use it.
hifi_geek
Dec 5, 2017
6
So you mean the new one (1%) would be better than the existing, or the other way around?
If anyone can post a link to a suitable or even the exact match that would be great. Thanks fellas.
kellys_eye
Jun 25, 2010
6,512
1% is better than 2% is better than 5% is better than 10% etc
If it is, as you say, a current limit for an LED then you can ignore the tolerance all together..... it won't make a blind bit of difference.
hifi_geek
Dec 5, 2017
6
Ok thanks. And with regard to the wattage, I assume there is no way to calculate this without testing the resistor using a multimeter?
Basically this board runs a small series of LED arrays to illuminate a logo.
