Visible light
Jeanguypataterubberboot
Jul 9, 2013
41
If a transmitter transmits a signal at the frequency of visible light. Will the human eye see it at the antenna?
Just curious.
Pierre
Don't know about anyone else but I still have to use a multimeter to check dc.
Looked at a lot of pcb's and never seen electricity yet.
14,289
A radio signal at light frequency is called light.
KJ6EAD
Aug 13, 2011
1,114
FuZZ1L0G1C
Mar 25, 2014
366
From what I've read up previously (open to correction):
Visible light is made up of photons.
Photons travel in packets called 'quanta'.. (i think).
They are unaffected by magnetic fields.
A photon is a massless particle, with higher energy as frequency increases.
The electron-volt energy ev is the energy that one photon posesses at a given frequency.
The wavelength of light is from about 685 nm (red) to 380 nm (violet).
That's a frequency of 442THZ red to 789THZ violet.
As a nm is 1E-9 m or 1 millionth of a mm, components would be larger than the longest (red) wavelength.
y Probably smaller than most molecules.
Which is why electron scanning or tunneling microscopes are used for <1um viewing.
So, no, ya cain't.
AnalogKid
Jun 10, 2015
3,050
Yes, but a single antenna will be less than 1μm long.
A single wavelength would be less than 1 um long, but an antenna could be any length you want, such as a (large) integral number of wavelengths.
ak
AnalogKid
Jun 10, 2015
3,050
Just turn lamp on and see if it glows
Apples and oranges. In terms of the source of the visible light, thermal radiation from a DC-heated resistor is not the same as an RF oscillator connected to an antenna. His question is whether or not the results of the two would be the same.
ak
14,289
I doubt that for the same wavelength you could make a difference between the radiation. Maybe with some very sophisticated equipment by judging from the noise and harmonic content (as you may discern laser light from LED light by the difference in coherence). Only that a heated resistor will emit a broaad spectrum of light, not a "single" frequency.
14,479
Actually, AK response is pretty good
You are not going to be transmitting RF at thermal frequencies
Thermal freq's are IR ( Infra-red) RF is much lower
14,479
Then it transmits light. You don't use antennas to transmit light, you use lenses or mirrors..
you use filaments in light globes, semi conductor interactions in LEDs to do the transmitting ….. lenses and mirrors just do focussing/reflecting they don't generate light
14,289
I agree I haven't been as precise as I should have been: I was thinking along the lines of beam forming or directional reception.
14,289
The op's question concerned
RF,visible light, infrared etc. all are electromagnetic waves distinct by the wavelength (or freqency, whichever you prefer).
The original question was not about thermal radiation. A laser, for example, can be considered an oscillator at the wavelength of visible light and would fit the op's question better.
AnalogKid
Jun 10, 2015
3,050
I wasn't addressing differences in the radiation, only my interpretation of the OP's original question about the generation of the radiation. If you (or the crazies at NIST) build a sinewave oscillator circuit that oscillates at the frequency of green, will you see green?
ak
Externet
Aug 24, 2009
943
The transmitter that transmits a signal at the frequency of light, will be a PN junction like a LED or laser.
The human eye will see the light emitted, but it is not called antenna, it is a light emitter.
